causes:blacksmithing [2020/11/01 21:03] jabelone |
causes:blacksmithing [2022/06/20 21:56] zacmarcus |
- | <panel> | ||
- | {{ : causes:forge.jpeg?direct&400|The forge area}} | ||
- | <WRAP> | ||
- | |**Location** | The Forge is in the Hardstand, immediately to your right after the first container. | | ||
- | |**Cause Leader** | To be updated | | ||
- | |**Objective** | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing, metal forging and sand casting. | | ||
- | |**Members** | [[https://portal.hsbne.org/cause/list/|Portal Cause Membership]] | | ||
- | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/blacksmithing|Forum Category]] \\ [[https://discord.gg/mfURB4|Discord Chat]] \\ [[https://trello.com/invite/b/tTIJx7YS/c528d5acd464469b4903db1a5881b4d3/forge|Trello Task Tracking]] | | ||
- | |**Operating Policy** | [[causes:blacksmithing:operatingpolicy|Policy]] | | ||
- | </panel> | ||
- | ===== Cause Area Expectations ===== | ||
- | * Please leave the area as clean or cleaner than you found it. | ||
- | * Please make sure to put money in the donation tin for consumables. | ||
- | * Please return tools to their homes. | ||
- | ===== Cause Owned Equipment ===== | ||
- | <nspages tools:blacksmithing -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
- | ===== Member Owned Equipment on Loan ===== | ||
- | ===== Ongoing Budgets ===== | ||
- | Monthly Consumables Discretionary - $100. This is a discretionary budget for the Cause Leader | ||
- | ===== Current Goals ===== | ||
- | ===== Proposed Classes ===== | ||
- | When finished using the cause area, members must: | ||
- | - Ensure that all tools/equipment is put away in their designated areas after use. | ||
- | - The casting furnace is covered to protect it from rain. | ||
- | - Clean up any mess caused by work | ||
- | - Gas cylinders are removed and locked in cage | ||
- | - donations for fuel/consumables use left in donations tin/ through spacebucks | ||
- | Weekly tasks will include: | ||
- | - Sweeping the floor | ||
- | - emptying bins (steel recycling/aluminium recycling/rubbish) | ||
- | Monthly tasks: | ||
- | - stocktake of fuel | ||
- | - stocktake of tools | ||
- | - identification of improvement areas | ||
- | Meetings will be announced with 7 days notice, and will happen on Tuesdays. | ||
- | Inductions can be held by any member who has been inducted on the relevant equipment, in line with the cause operating policy. | ||
+ | This page has moved to the [[teams:blacksmithing|Blacksmithing & Casting Teams]] page. | ||
- causes/blacksmithing
