Next revision
causes:blacksmithing [2020/11/01 21:05]
jabelone [Blacksmithing and Casting Cause]
causes:blacksmithing [2022/06/20 21:56] (current)
zacmarcus
Line 1: Line 1:
 ====== Blacksmithing and Casting Cause ====== ====== Blacksmithing and Casting Cause ======
-<​panel>​
-{{ : causes:​forge.jpeg?​direct&​400|The forge area}}
-<​WRAP>​
-|**Location** ​        | The Forge is in the Hardstand, immediately to your right after the first container. |
-|**Cause Leader** ​    | To be updated |
-|**Objective** ​       | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing,​ metal forging and sand casting. |
-|**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] |
-|**Communications** ​  | [[https://​forum.hsbne.org/​c/​cause-effect/​blacksmithing|Forum Category]] \\ [[https://​discord.gg/​XpMznccTEt|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​tTIJx7YS/​c528d5acd464469b4903db1a5881b4d3/​forge|Trello Task Tracking]] |
-|**Operating Policy** | [[causes:​blacksmithing:​operatingpolicy|Policy]] |
-</​WRAP>​
-</​panel>​
-===== Cause Area Expectations =====
-  * Please leave the area as clean or cleaner than you found it.
-  * Please make sure to put money in the donation tin for consumables.
-  * Please return tools to their homes.
-===== Cause Owned Equipment =====
-<nspages tools:​blacksmithing -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
-===== Member Owned Equipment on Loan =====
-===== Ongoing Budgets =====
-Monthly Consumables Discretionary - $100. This is a discretionary budget for the Cause Leader
-===== Current Goals =====
-===== Proposed Classes =====
-===== Cleaning plan =====
-When finished using the cause area, members must:
-  - Ensure that all tools/​equipment is put away in their designated areas after use.
-  - The casting furnace is covered to protect it from rain.
-  - Clean up any mess caused by work
-  - Gas cylinders are removed and locked in cage
-  - donations for fuel/​consumables use left in donations tin/ through spacebucks
-Weekly tasks will include:
-  - Sweeping the floor
-  - emptying bins (steel recycling/​aluminium recycling/​rubbish)
-Monthly tasks:
-  - stocktake of fuel
-  - stocktake of tools
-  - identification of improvement areas
-Meetings will  be announced with 7 days notice, and will happen on Tuesdays.
-Inductions can be held by any member who has been inducted on the relevant equipment, in line with the cause operating policy.
 +This page has moved to the [[teams:​blacksmithing|Blacksmithing & Casting Teams]] page.
  • causes/blacksmithing.1604228737
  • Last modified: 4 years ago
  • by jabelone
