causes:craftpunk [2019/06/08 00:18] |
causes:craftpunk [2020/11/04 21:44] lonepiper_paula |
- | <WRAP center round box 60%> | + | ====== Craftpunk Cause ====== |
- | ====== Craft Punk Cause ====== | + | {{ :causes:craftpunk.jpg?direct&600}} |
- | **Location:** The Craft Punk room is the room on the right at the end of the Green Room. | + | <WRAP> |
- | **Cause Leader:** Meka Beecham, aka "Boo" | + | |**Location** | The Craftpunk room is the room on the right at the end of the Green Room.| |
+ | |**Cause Leader** | Craftpunk is using an anarchy-based model of self-governance, but notable Craftpunkians are Meka, Paula and Emily (They can be found on Discord as Boo, LonePiper and Pommygirl) \\ A clear explanation of this system can be found [[https://www.youtube.com/watch?v=FSbl16vTovU|here.]]| | ||
- | **Objective:** Craft Punk is a Cause dedicated to the more artistic pursuits of HSBNE members. Previously known as the "Createatorium", Craft Punk specialises in cosplay, sewing, moulding and casting, painting, models, pottery and kiln firing, screen printing, sculpture, etc. | ||
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/craft-punk|Forums]] and #cause-craftpunk in [[https://discord.gg/avtkH5t|Discord Chat]]. | ||
- | * Please leave the area as clean or cleaner than you found it. | + | * Leave the area as clean or cleaner than you found it.\\ |
- | * Please make sure to put money in the donation tin for consumables. | + | |
- | * Please return tools to their homes. | + | |
- | ===== Tools requiring Induction ===== | + | * Please make sure to put money in the donation tin (see below) for consumables that you appreciated using so that we can replenish them.\\ |
- | Currently none of our tools require induction. | + | |
- | ===== Process for becoming a Maintainer ===== | + | * Only use tools in the way they are intended to be used.\\ |
- | Tools are generally maintained by the cause leader, so check in with them before embarking on fixing a tool. | + | |
- | ===== Ongoing Budgets ===== | + | * Only use tools you know how to use or have been inducted on.\\ |
- | Monthly Consumables Discretionary - $100. This is for reimbursing purchases of things required from the Electronics Cause Consumables list. | + | * Ask for help or guidance when you need it.\\ |
+ | * Because art and creativity is subjective and personal, please do not provide unsolicited critique, suggestions or help with someone’s project. Instead, you may wish to offer your help, but allow the crafter to decline.\\ | ||
- | ===== Current Goals ===== | + | * Respect that some crafters may not want to break their focus to talk or answer questions. The exception to this rule is in the case of dangerous or disrespectful tool use and emergencies.\\ |
- | ====== Current projects ====== | ||
- | * Clean and tidy room | ||
- | * Install more desks | ||
- | ====== Pending projects ====== | + | {{:tools:craftpunk:img_20201011_124333.jpg?200|}} |
- | * Mark all tools and items belonging to the Craft Punk cause with specified colour and tag | + | |
- | * Find spots for all equipment, and mark it either on shadow boards or labels on cupboards and benches | + | |
- | * Mark specified spots that HSBNE members can leave active projects (green ticket shelf) | + | |
- | ===== Proposed Classes ===== | ||
- | ====== Upcoming ====== | ||
- | * Screen printing monochrome- Photo-emulsion (induction) | ||
- | * Basics of sewing (induction) | ||
- | * Basics of Embroidery | ||
- | ====== Future classes ====== | + | |
+ | ===== Craftpunk Tools ===== | ||
+ | <nspages tools:craftpunk -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
+ | ===== Events and Classes ===== | ||
+ | All of HSBNE's classes and events can be found [[https://www.eventbrite.com.au/o/hsbne-inc-4654630925|on Eventbrite]]. Craftpunk also runs regular events, such as Working Bees to improve our space, and Classes, so that members can learn a new skill in a relaxed, friendly environment.\\ | ||
+ | === Upcoming === | ||
+ | * No currently planned classes. | ||
+ | === Possible Future classes === | ||
* Screen printing multiple colours | * Screen printing multiple colours | ||
+ | * Screen printing monochrome- Photo-emulsion | ||
+ | ===== Meetings ===== | ||
+ | Meetings are held to decide on cause goals and large (over $100) spending items.\\ | ||
+ | Meeting minutes can all be found here: [[meetings:causes:craftpunk:| Craftpunk minutes]]\\ | ||
+ | Meeting minutes are kept on the Wiki, and cross-posted to the forums.\\ | ||
+ | Any member of Craftpunk can call a meeting.\\ | ||
+ | ===== History of Craftpunk ===== | ||
+ | Previously known as the "Createatorium", Meka started this cause in _____ to expand on HSBNE's creative potential. | ||
- causes/craftpunk
