causes:digitalfabrication [2018/10/15 14:53] |
- | Also known as the Digifab Cause, this cause's goals are to provide, maintain, and run classes for equipment in the principles of digital fabrication and related fabrication services. Digifab currently operates out of the room on the left at the end of the Green Room. The room is accessed via Swipe card for extra security & registering usage patterns etc. The hope is that in the future the door can be temporarily disabled to only open for certain approved members when certain dangerous actions are taking place inside the room (eg calibrating the [[tools:lasercutter|laser cutter]], which requires temporarily disabling the machine's safety features so it can be operated with the lid open and the raw beam accessible, so everyone in the room should be wearing safety goggles). | + | {{ : causes:digifab.jpg?direct&600|The digifab room}} |
- | Because many of the pieces of equipment in this room are sensitive or delicate in their operation, this room tries to operate as a "cleaner" environment than the rest of the space, which is often a bit too dusty for Digifab's equipment. Digifab members therefore regularly vacuum the carpet, wipe down the benches, and try to keep all surfaces clear of clutter. And as always, anyone who uses the equipment in this room is requested to leave the equipment cleaner than you found it. | + | |**Location** | Digifab is located in the left most room when you walk into the green room and turn towards Eat St. | |
- | ===== Members ===== | + | </WRAP> |
- | Cause Leader: Aaron Bycroft, aka "Crofty" | + | |
- | ===== Notable Equipment ===== | + | ===== Cause Area Rules ===== |
- | * Large Format Printer | + | Please: |
- | * Red [[tools:lasercutter|Laser Cutter]] | + | * leave the area cleaner than you found it. |
- | * CAD modelling computer | + | * don’t create mess in the Digifab room, our tools are sensitive to dust etc. |
- | * [[http://www.filastruder.com|Filastruder]], a 3D printer filament extruder & recycler | + | * return tools to their homes and don’t remove them from the Digifab room. |
- | * Right CR-10 | + | * read the wiki before attempting to use a tool in Digital Fabrication. |
- | * Left CR-10 | + | * don’t leave machines running unattended. |
+ | * don’t use tools that are marked as out of order. | ||
+ | * pay for all consumables you use unless they are for improving digifab or HSBNE infrastructure. | ||
+ | * don’t use your own consumables in a machine unless you have received permission from a maintainer of that machine. | ||
- | ===== Current Projects ===== | ||
- | * Finish upgrades to Red Laser Cutter | ||
- | ===== Classes ===== | + | ===== Cause Owned Equipment ===== |
+ | <nspages tools:digitalfabrication -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | ||
+ | ===== Tools requiring Induction ===== | ||
+ | **3D Printers:** | ||
+ | ===== Tools requiring Supervision ===== | ||
+ | - Laser cutters: The machines themselves require supervision, so a supervisor must be around for the machines to be operated by anyone. | ||
+ | ===== Process for becoming a Supervisor ===== | ||
+ | Becoming a Supervisor is not to be considered a shortcut to having unsupervised full access to a machine; it’s a role requiring a greater & more regular contribution of your time than a Maintainer. It means you know a machine well enough the you’re the person the Maintainers go to when they’re not sure of something. If you’re not already a Maintainer, start with that role first. | ||
+ | Supervisors should have spent a reasonable amount of time as a Maintainer and can point to some recent tasks they have performed to maintain or improve the machine. If you’re stuck for tasks, ask the Cause Leader, other Maintainers or Supervisors, or check Trello for our current To-Do list. We try to keep some simple tasks aside just for newcomers, but if you feel they’re all too difficult, you’re welcome to have a go with finishing a task on one of our similar machines. Helping to bring an offline machine into operation is big brownie points. | ||
+ | ===== . Ongoing Budgets ===== | ||
+ | * Clean up room | ||
+ | * Price up supplies. | ||
+ | * Write up Photon workflow. | ||
+ | * Write up Up Mini workflow | ||
* How to Vector | * How to Vector | ||
* How to 3D Model | * How to 3D Model | ||
* How to 3D Print | * How to 3D Print | ||
+ | ===== Cleaning Policy ===== | ||
+ | Digital Fabrication contains equipment that is sensitive to dust and mess. The room must be cleaned by users of the tools according to the signage in the room and this policy. There is a whiteboard in the room that indicates the last time cleaning happened. If it has been longer than the requirement for the tool you’re using, you must vacuum the room and wipe down all horizontal surfaces. You will be dinged and referred to the executive for a potential ban (depending on the case) if you ignore this rule. | ||
+ | ===== Current Projects ===== | ||
+ | * Finish upgrades to Red Laser Cutter | ||
+ | ===== Classes ===== | ||
- causes/digitalfabrication
