Last revision Both sides next revision
causes:digitalfabrication [2019/06/08 17:08]
causes:digitalfabrication [2020/10/28 00:23]
jabelone
Line 1: Line 1:
-<WRAP center round box 60%> +====== ​Digifab ​Cause ======
-====== ​Digital Fabrication ​Cause ====== +{{ causes:​digifab.jpg?​direct&​600|The digifab ​room}}
-**Location:** The Digital Fabrication ​room is the room on the left at the end of the Green Room farthest from the driveway.+<​WRAP>​
-**Cause Leader:** Cause Leader: ​Aaron Bycroft, ​aka "​Crofty"​+|**Location** ​        | Digifab is located in the left most room when you walk into the green room and turn towards Eat St. |
 +|**Cause ​Team** ​      | Brendan Halliday (@nog3), ​Aaron Bycroft ​(@crofty) and Michael King (@doc) |
 +|**Objective** ​       | Digifab'​s goals are to provide and maintain equipment in the principles of digital fabricationprimarily 3D printing and laser cutting. |
 +|**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] |
 +|**Communications** ​  | [[https://​forum.hsbne.org/​c/​cause-effect/​digital-fabrication|Forums]] \\ [[https://​discord.gg/​z2sTZB|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​ERpgbqEh/​78075b9da25bd2e659c41640dd442b30/​digifab|Trello Task Tracking]] |
 +|**Recommended Suppliers**| [[https://​wiki.hsbne.org/​causes/​digitalfabrication/​suppliers|See here]]. |
 +|**Operating Policy** | [[causes:​digitalfabrication:​operatingpolicy| Operating Policy should be split out into it's own page]] |
-**Objective:​** Digital Fabrication'​s goals are to provide, maintain, and run classes for equipment in the principles of digital fabrication and related fabrication services ​
-**Members:​** See [[https://​portal.hsbne.org/​cause/​list/​|Current List]]
-**Communications:​** [[https://​forum.hsbne.org/​c/​cause-effect/​digital-fabrication|Forums]] and #​cause-digifab in [[https://​discord.gg/​avtkH5t|Discord Chat]].
 </​WRAP>​ </​WRAP>​
-===== Cause Area Expectations ​===== +===== Cause Area Rules =====
-  * Please ​leave the area as clean or cleaner than you found it. +Please:
-  * Please make sure to put money in the donation tin for consumables & tool use+  * leave the area cleaner than you found it.
-  * Please ​return tools to their homes.+  * don’t create mess in the Digifab room, our tools are sensitive to dust etc
 +  * return tools to their homes and don’t remove them from the Digifab room.
 +  * read the wiki before attempting to use a tool in Digital Fabrication.
 +  * don’t leave machines running unattended.
 +  * don’t use tools that are marked as out of order.
 +  * pay for all consumables you use unless they are for improving digifab or HSBNE infrastructure.
 +  * don’t use your own consumables in a machine unless you have received permission from a maintainer of that machine.
 +  * precisely follow a tool’s workflow unless you have received permission from a maintainer of that tool to adjust it.
 +  * report all broken or misbehaving tools using the “Report Issue” link in the portal or by sending an email to [[mailto:​issues@hsbne.org|issues@hsbne.org]].
-===== Notable ​Equipment ===== +
-  * Red [[tools:lasercutter|Laser Cutter]] +===== Cause Owned Equipment =====
-  * [[tools:​3dprinters|FDM 3D Printers]]Left CR-10, Right CR-10, Taz 5, Up Mini +<​nspages ​tools:digitalfabrication -exclude:home -usePictures ​-h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -defaultPicture="​{{:wiki:logo.png}}" -naturalOrder>​
-  * Resin 3D printer[[tools:3dprinters:​photon|Anycubic Photon]] +
-  * [[https://​www.filastruder.com|Filastruder]],​ a 3D printer filament extruder & recycler +
-  * CAD modelling computer +
-  * Acrylic sheet bender+
 ===== Tools requiring Induction ===== ===== Tools requiring Induction =====
-[[tools:​lasercutter|Red Laser cutter]]
 +**3D Printers:**
 +  * Induction process is to read the entire [[tools:​digitalfabrication:​3dprinters:​|3D printers page]], in addition to the machine specific page.
 +**Redsail 60w Laser Cutter: **
 +  * For the laser cutter, it is a hands-on class on how to use the machine after the Supervisor has checked the machine and your competency. ​
 +  * Use requires supervision even after this, but it will generally be less hands on and more the Supervisor ensuring the machine is operating properly.
 +  * Supervisors are listed on the tool's wiki page.
 ===== Tools requiring Supervision ===== ===== Tools requiring Supervision =====
-[[tools:​lasercutter|Red ​Laser cutter]]+  - Laser cutters: The machines themselves require supervision,​ so a supervisor must be around for the machines to be operated by anyone.
-===== Process for becoming a Maintainer ​===== +===== Process for becoming a Supervisor ​=====
-Tools are generally maintained by the maintainers listed on the relevant tool Wiki pageso check in with them before embarking ​on fixing ​tool.+Becoming a Supervisor is not to be considered a shortcut to having unsupervised full access to a machine; it’s a role requiring a greater & more regular contribution of your time than a Maintainer. It means you know a machine well enough ​the you’re ​the person the Maintainers go to when they’re not sure of something. If you’re not already a Maintainerstart with that role first.
 +Becoming a Supervisor doesn’t have a 100% formally described method as it varies depending ​on the state of our current equipment and the need for additional Supervisors,​ but guidelines are given below. Final discretion on being Supervisor is up to the Cause Leader.
-===== Ongoing Budgets ​=====+Supervisors should have spent a reasonable amount of time as a Maintainer and can point to some recent tasks they have performed to maintain or improve the machine. If you’re stuck for tasks, ask the Cause Leader, other Maintainers or Supervisors,​ or check Trello for our current To-Do list. We try to keep some simple tasks aside just for newcomers, but if you feel they’re all too difficult, you’re welcome to have a go with finishing a task on one of our similar machines. Helping to bring an offline machine into operation is big brownie points.
 +A Supervisor should have an in-depth knowledge of how not just that type of machine works in general, but also the quirks & oddities of our specific machines. For the former, we have a short 10-ish question test - keep in mind it doesn’t check for competency, it only checks that you know where to find important information. Despite this limitation of our current test, a Supervisor should be able to not just reference our existing documentation,​ but add to it whenever they spot a weak point. Regarding knowledge of any quirks & oddities of our specific machines, the only real way to learn this is by going through all our existing documentation plus experience by spending time with the machine. As a rough guide, you should have at least 10 hours of hands-on use with this machine.
 +A Supervisor should be able to not only run the machine without others present, but know what to do when (not if) it breaks. This doesn’t just mean slapping a Borked or Broken ticket on it and walking away, but actually diagnosing and repairing the problem to get the machine up & running again. If you haven’t had the machine break on you already as a Maintainer, this ability may be tested by having one of the current Supervisors deliberately introduce a fault for you to find & fix.
 +While it is a requirement of HSBNE’s membership that all members must keep relatively up to date with HSBNE’s happenings, Supervisors are additionally required to be actively involved in the relevant sections on Trello, Slack and our Forums. Supervisors must be available to answer questions for Maintainers & users whenever possible, and must be willing and able to supervise others using the machine as often as they can.
 +The list of current Supervisors may be revised every 3-6 months at a Digifab cause meeting, and will be used to identify if any of the Supervisors are currently incapable of continuing to perform the above duties. We all know life sometimes gets in the way and a Supervisor’s status will not be withdrawn without fair warning to them, but the position is intended only for those who are active with the machine.
 +===== Process for becoming a Maintainer ​=====
 +To become a maintainer for any of the Digifab machines you must demonstrate competency to at least one of the existing Maintainers and the Cause Leader. The easiest way to do this is by doing some of the tasks on our Trello To-Do list, or by asking one of the Supervisors,​ other Maintainers or the Cause Leader for suitable tasks.
-Monthly ​Consumables Discretionary ​- $100. This is for reimbursing ​purchases of cause consumables.+===== . Ongoing Budgets =====
 +  * Monthly ​consumables discretionary ​- $100. This is for purchases of cause consumables ​not included in any of the budgets below. Purchases that form part of this budget must be approved by the cause leader.
 +  * Quarterly filament discretionary - $300. This budget can be used every 3 months to buy new filament. Purchases that form part of this budget must be approved by the cause leader.
 +  * Monthly repair discretionary - $150. This budget can be used to purchase new parts and cover any expenses related to repairs or upgrades of digifab tools as determined necessary by the cause leader.
 ===== Current Goals ===== ===== Current Goals =====
Line 50: Line 79:
   * How to Filastrude   * How to Filastrude
-===== Cleaning ​plan ===== +===== Cleaning ​Policy ​=====
-Digital Fabrication contains equipment that is sensitive to dustand mess. The room must be vacuumed ​by users of the tools at least once fortnight.+Digital Fabrication contains equipment that is sensitive to dust and mess. The room must be cleaned ​by users of the tools according to the signage in the room and this policy. There is whiteboard in the room that indicates the last time cleaning happened. If it has been longer than the requirement for the tool you’re using, you must vacuum the room and wipe down all horizontal surfaces. You will be dinged and referred to the executive for a potential ban (depending on the case) if you ignore this rule.
  • causes/digitalfabrication
  • Last modified: 2 years ago
  • by devians
