Last revision Both sides next revision
causes:digitalfabrication [2018/10/15 14:53]
causes:digitalfabrication [2020/10/28 00:23]
jabelone
Line 1: Line 1:
-====== ​Digital Fabrication ​Cause ====== +====== ​Digifab ​Cause ======
-Also known as the Digifab Cause, this cause'​s goals are to provide, maintain, and run classes for equipment in the principles of digital fabrication and related fabrication servicesDigifab currently operates out of the room on the left at the end of the Green Room. The room is accessed via Swipe card for extra security ​registering usage patterns etc. The hope is that in the future the door can be temporarily disabled to only open for certain approved members when certain dangerous actions are taking place inside the room (eg calibrating the [[tools:​lasercutter|laser cutter]], which requires temporarily disabling the machine'​s safety features so it can be operated with the lid open and the raw beam accessible, so everyone in the room should be wearing safety goggles).+{{ : causes:​digifab.jpg?direct&600|The digifab ​room}}
 +<​WRAP>​
-Because many of the pieces of equipment in this room are sensitive or delicate in their operation, this room tries to operate as a "​cleaner"​ environment than the rest of the spacewhich is often a bit too dusty for Digifab'​s equipment. Digifab members therefore regularly vacuum ​the carpet, wipe down the benches, and try to keep all surfaces clear of clutterAnd as always, anyone who uses the equipment in this room is requested to leave the equipment cleaner than you found it.+|**Location** ​        | Digifab is located in the left most room when you walk into the green room and turn towards Eat St. |
 +|**Cause Team** ​      | Brendan Halliday (@nog3)Aaron Bycroft (@crofty) and Michael King (@doc) |
 +|**Objective** ​       | Digifab'​s ​goals are to provide and maintain ​equipment ​in the principles of digital fabricationprimarily 3D printing ​and laser cutting. |
 +|**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] |
 +|**Communications** ​  | [[https://​forum.hsbne.org/​c/​cause-effect/​digital-fabrication|Forums]] \\ [[https://​discord.gg/​z2sTZB|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​ERpgbqEh/​78075b9da25bd2e659c41640dd442b30/​digifab|Trello Task Tracking]] |
 +|**Recommended Suppliers**| [[https://​wiki.hsbne.org/​causes/​digitalfabrication/​suppliers|See here]]. |
 +|**Operating Policy** | [[causes:​digitalfabrication:​operatingpolicy| Operating Policy should be split out into it's own page]] |
-===== Members ===== +</​WRAP>​
-Cause Leader: Aaron Bycroft, aka "​Crofty"​+
-===== Notable Equipment ​===== +===== Cause Area Rules =====
-  * Large Format Printer +Please:
-  * Red [[tools:​lasercutter|Laser Cutter]] +  * leave the area cleaner than you found it.
-  * CAD modelling computer +  * don’t create mess in the Digifab room, our tools are sensitive to dust etc.
-  * [[http://​www.filastruder.com|Filastruder]], ​3D printer filament extruder & recycler +  * return tools to their homes and don’t remove them from the Digifab room.
-  * Right CR-10 +  * read the wiki before attempting to use a tool in Digital Fabrication.
-  * Left CR-10+  * don’t leave machines running unattended.
 +  * don’t use tools that are marked as out of order.
 +  * pay for all consumables you use unless they are for improving digifab or HSBNE infrastructure.
 +  * don’t use your own consumables in machine unless you have received permission from a maintainer of that machine.
 +  * precisely follow a tool’s workflow unless you have received permission from a maintainer of that tool to adjust it.
 +  * report all broken or misbehaving tools using the “Report Issue” link in the portal or by sending an email to [[mailto:​issues@hsbne.org|issues@hsbne.org]].
-===== Current Projects =====
-  * Finish upgrades to Red Laser Cutter
-===== Classes =====+===== Cause Owned Equipment =====
 +<nspages tools:​digitalfabrication -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -defaultPicture="​{{:​wiki:​logo.png}}"​ -naturalOrder>​
 +===== Tools requiring Induction =====
 +**3D Printers:​**
 +  * Induction process is to read the entire [[tools:​digitalfabrication:​3dprinters:​|3D printers page]], in addition to the machine specific page.
 +**Redsail 60w Laser Cutter: **
 +  * For the laser cutter, it is a hands-on class on how to use the machine after the Supervisor has checked the machine and your competency.
 +  * Use requires supervision even after this, but it will generally be less hands on and more the Supervisor ensuring the machine is operating properly.
 +  * Supervisors are listed on the tool's wiki page.
 +===== Tools requiring Supervision =====
 +  - Laser cutters: The machines themselves require supervision,​ so a supervisor must be around for the machines to be operated by anyone.
 +===== Process for becoming a Supervisor =====
 +Becoming a Supervisor is not to be considered a shortcut to having unsupervised full access to a machine; it’s a role requiring a greater & more regular contribution of your time than a Maintainer. It means you know a machine well enough the you’re the person the Maintainers go to when they’re not sure of something. If you’re not already a Maintainer, start with that role first.
 +Becoming a Supervisor doesn’t have a 100% formally described method as it varies depending on the state of our current equipment and the need for additional Supervisors,​ but guidelines are given below. Final discretion on being a Supervisor is up to the Cause Leader.
 +Supervisors should have spent a reasonable amount of time as a Maintainer and can point to some recent tasks they have performed to maintain or improve the machine. If you’re stuck for tasks, ask the Cause Leader, other Maintainers or Supervisors,​ or check Trello for our current To-Do list. We try to keep some simple tasks aside just for newcomers, but if you feel they’re all too difficult, you’re welcome to have a go with finishing a task on one of our similar machines. Helping to bring an offline machine into operation is big brownie points.
 +A Supervisor should have an in-depth knowledge of how not just that type of machine works in general, but also the quirks & oddities of our specific machines. For the former, we have a short 10-ish question test - keep in mind it doesn’t check for competency, it only checks that you know where to find important information. Despite this limitation of our current test, a Supervisor should be able to not just reference our existing documentation,​ but add to it whenever they spot a weak point. Regarding knowledge of any quirks & oddities of our specific machines, the only real way to learn this is by going through all our existing documentation plus experience by spending time with the machine. As a rough guide, you should have at least 10 hours of hands-on use with this machine.
 +A Supervisor should be able to not only run the machine without others present, but know what to do when (not if) it breaks. This doesn’t just mean slapping a Borked or Broken ticket on it and walking away, but actually diagnosing and repairing the problem to get the machine up & running again. If you haven’t had the machine break on you already as a Maintainer, this ability may be tested by having one of the current Supervisors deliberately introduce a fault for you to find & fix.
 +While it is a requirement of HSBNE’s membership that all members must keep relatively up to date with HSBNE’s happenings, Supervisors are additionally required to be actively involved in the relevant sections on Trello, Slack and our Forums. Supervisors must be available to answer questions for Maintainers & users whenever possible, and must be willing and able to supervise others using the machine as often as they can.
 +The list of current Supervisors may be revised every 3-6 months at a Digifab cause meeting, and will be used to identify if any of the Supervisors are currently incapable of continuing to perform the above duties. We all know life sometimes gets in the way and a Supervisor’s status will not be withdrawn without fair warning to them, but the position is intended only for those who are active with the machine.
 +===== Process for becoming a Maintainer =====
 +To become a maintainer for any of the Digifab machines you must demonstrate competency to at least one of the existing Maintainers and the Cause Leader. The easiest way to do this is by doing some of the tasks on our Trello To-Do list, or by asking one of the Supervisors,​ other Maintainers or the Cause Leader for suitable tasks.
 +===== . Ongoing Budgets =====
 +  * Monthly consumables discretionary - $100. This is for purchases of cause consumables not included in any of the budgets below. Purchases that form part of this budget must be approved by the cause leader.
 +  * Quarterly filament discretionary - $300. This budget can be used every 3 months to buy new filament. Purchases that form part of this budget must be approved by the cause leader.
 +  * Monthly repair discretionary - $150. This budget can be used to purchase new parts and cover any expenses related to repairs or upgrades of digifab tools as determined necessary by the cause leader.
 +===== Current Goals =====
 +  * Clean up room
 +  * Price up supplies.
 +  * Write up Photon workflow.
 +  * Write up Up Mini workflow
 +===== Proposed ​Classes =====
   * How to Vector   * How to Vector
   * How to 3D Model   * How to 3D Model
   * How to 3D Print   * How to 3D Print
   * How to Filastrude   * How to Filastrude
 +===== Cleaning Policy =====
 +Digital Fabrication contains equipment that is sensitive to dust and mess. The room must be cleaned by users of the tools according to the signage in the room and this policy. There is a whiteboard in the room that indicates the last time cleaning happened. If it has been longer than the requirement for the tool you’re using, you must vacuum the room and wipe down all horizontal surfaces. You will be dinged and referred to the executive for a potential ban (depending on the case) if you ignore this rule.
 +===== Current Projects =====
 +  * Finish upgrades to Red Laser Cutter
 +===== Classes =====
  • causes/digitalfabrication
  • Last modified: 2 years ago
  • by devians
