causes:digitalfabrication [2019/06/08 00:38] |
- | <WRAP center round box 60%> | + | ====== Digifab Cause ====== |
- | ====== Digital Fabrication Cause ====== | + | {{ : causes:digifab.jpg?direct&600|The digifab room}} |
- | **Location:** The Digital Fabrication room is the room on the left at the end of the Green Room. | + | <WRAP> |
- | ===== Cause Area Expectations ===== | + | ===== Cause Area Rules ===== |
- | * Please leave the area as clean or cleaner than you found it. | + | Please: |
- | * Please make sure to put money in the donation tin for consumables. | + | * leave the area cleaner than you found it. |
- | * Please return tools to their homes. | + | * don’t create mess in the Digifab room, our tools are sensitive to dust etc. |
+ | * return tools to their homes and don’t remove them from the Digifab room. | ||
+ | * read the wiki before attempting to use a tool in Digital Fabrication. | ||
+ | * don’t leave machines running unattended. | ||
+ | * don’t use tools that are marked as out of order. | ||
+ | * pay for all consumables you use unless they are for improving digifab or HSBNE infrastructure. | ||
+ | * don’t use your own consumables in a machine unless you have received permission from a maintainer of that machine. | ||
- | ===== Notable Equipment ===== | + | |
- | * Large Format Printer | + | ===== Cause Owned Equipment ===== |
- | * Red [[tools:lasercutter|Laser Cutter]] | + | <nspages tools:digitalfabrication -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> |
- | * CAD modelling computer | + | |
- | * [[http://www.filastruder.com|Filastruder]], a 3D printer filament extruder & recycler | + | |
- | * Right CR-10 | + | |
- | * Left CR-10 | + | |
- | [[tools:lasercutter|Red Laser cutter]] | ||
+ | **3D Printers:** | ||
- | [[tools:lasercutter|Red Laser cutter]] | + | - Laser cutters: The machines themselves require supervision, so a supervisor must be around for the machines to be operated by anyone. |
- | ===== Process for becoming a Maintainer ===== | + | ===== Process for becoming a Supervisor ===== |
- | Tools are generally maintained by the maintainers listed on the tool wiki page, so check in with them before embarking on fixing a tool. | + | Becoming a Supervisor is not to be considered a shortcut to having unsupervised full access to a machine; it’s a role requiring a greater & more regular contribution of your time than a Maintainer. It means you know a machine well enough the you’re the person the Maintainers go to when they’re not sure of something. If you’re not already a Maintainer, start with that role first. |
- | ===== Ongoing Budgets ===== | + | Supervisors should have spent a reasonable amount of time as a Maintainer and can point to some recent tasks they have performed to maintain or improve the machine. If you’re stuck for tasks, ask the Cause Leader, other Maintainers or Supervisors, or check Trello for our current To-Do list. We try to keep some simple tasks aside just for newcomers, but if you feel they’re all too difficult, you’re welcome to have a go with finishing a task on one of our similar machines. Helping to bring an offline machine into operation is big brownie points. |
- | Monthly Consumables Discretionary - $100. This is for reimbursing purchases of cause consumables. | + | A Supervisor should have an in-depth knowledge of how not just that type of machine works in general, but also the quirks & oddities of our specific machines. For the former, we have a short 10-ish question test - keep in mind it doesn’t check for competency, it only checks that you know where to find important information. Despite this limitation of our current test, a Supervisor should be able to not just reference our existing documentation, but add to it whenever they spot a weak point. Regarding knowledge of any quirks & oddities of our specific machines, the only real way to learn this is by going through all our existing documentation plus experience by spending time with the machine. As a rough guide, you should have at least 10 hours of hands-on use with this machine. |
+ | ===== . Ongoing Budgets ===== | ||
Line 50: | Line 79: | ||
- causes/digitalfabrication.1559918309
