causes:digitalfabrication [2020/04/11 12:01] 127.0.0.1 external edit |
- | <WRAP center round box 60%> | + | ====== Digifab Cause ====== |
- | ====== Digital Fabrication Cause ====== | + | {{ : causes:digifab.jpg?direct&600|The digifab room}} |
- | **Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | + | <WRAP> |
- | **Recommended Suppliers**: [[https://wiki.hsbne.org/causes/digitalfabrication/suppliers|See here]]. | ||
Line 32: | Line 31: | ||
- causes/digitalfabrication.1586570496
- by 127.0.0.1
