Next revision
causes:digitalfabrication [2020/04/12 17:05]
nogthree
causes:digitalfabrication [2021/12/31 15:48] (current)
Line 1: Line 1:
-====== ​Digital Fabrication ​Cause ====== +====== ​Digifab ​Cause ======
-<panel type="​default"​ title="">​ +{{ causes:​digifab.jpg?​direct&​600|The digifab ​room}}
-**Location:** The Digital Fabrication ​room is the room on the left at the end of the Green Room farthest from the driveway.+<​WRAP>​
-**Cause Leader:** Cause Leader: ​Aaron Bycroft, ​aka "​Crofty"​+|**Location** ​        | Digifab is located in the left most room when you walk into the green room and turn towards Eat St. |
 +|**Cause ​Team** ​      | Brendan Halliday (@nog3), ​Aaron Bycroft ​(@crofty) and Michael King (@doc) |
 +|**Objective** ​       | Digifab'​s goals are to provide and maintain equipment in the principles of digital fabricationprimarily 3D printing and laser cutting. |
 +|**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] |
 +|**Communications** ​  | [[https://​forum.hsbne.org/​c/​cause-effect/​digital-fabrication|Forums]] \\ [[https://​chat.hsbne.org/​|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​ERpgbqEh/​78075b9da25bd2e659c41640dd442b30/​digifab|Trello Task Tracking]] |
 +|**Recommended Suppliers**| [[https://​wiki.hsbne.org/​causes/​digitalfabrication/​suppliers|See here]]. |
 +|**Operating Policy** | [[causes:​digitalfabrication:​operatingpolicy| Operating Policy should be split out into it's own page]] |
-**Objective:​** Digital Fabrication'​s goals are to provide, maintain, and run classes for equipment in the principles of digital fabrication and related fabrication services  +</WRAP>
-**Members:​** See [[https://​portal.hsbne.org/​cause/​list/​|Current List]] +
-**Recommended Suppliers**:​ [[https://​wiki.hsbne.org/​causes/​digitalfabrication/​suppliers|See here]]. +
-**Communications:​** [[https://​forum.hsbne.org/​c/​cause-effect/​digital-fabrication|Forums]] and #​cause-digifab in [[https://​discord.gg/​avtkH5t|Discord Chat]]. +
-</panel>+
 ===== Cause Area Rules ===== ===== Cause Area Rules =====
Line 32: Line 31:
 ===== Tools requiring Induction ===== ===== Tools requiring Induction =====
 **3D Printers:** **3D Printers:**
-   * Induction process is to demonstrate safe use of the machine while setting up a print.
-   * Maintainers are listed on the wiki for each machine.
-**Redsail 60w Laser Cutter: ** +  * Induction process ​is to read the entire [[tools:​digitalfabrication:​3dprinters:​|3D printers page]]in addition to the machine ​specific ​page.
-   * For the laser cutter, it is a hands-on class on how to use the machine after the Supervisor has checked the machine and your competency.  +
-   * Use requires supervision even after thisbut it will generally be less hands on and more the Supervisor ensuring ​the machine ​is operating properly. +
-   * Supervisors are listed on the tool's wiki page.+
 +**Redsail 60w Laser Cutter: **
 +  * For the laser cutter, it is a hands-on class on how to use the machine after the Supervisor has checked the machine and your competency. ​
 +  * Use requires supervision even after this, but it will generally be less hands on and more the Supervisor ensuring the machine is operating properly.
 +  * Supervisors are listed on the tool's wiki page.
 ===== Tools requiring Supervision ===== ===== Tools requiring Supervision =====
   - Laser cutters: The machines themselves require supervision,​ so a supervisor must be around for the machines to be operated by anyone.   - Laser cutters: The machines themselves require supervision,​ so a supervisor must be around for the machines to be operated by anyone.
  • causes/digitalfabrication.1586675107
  • Last modified: 4 years ago
  • by nogthree
