causes:digitalfabrication [2020/10/28 00:22] jabelone |
Line 4: | Line 4: | ||
|**Location** | Digifab is located in the left most room when you walk into the green room and turn towards Eat St. | | |**Location** | Digifab is located in the left most room when you walk into the green room and turn towards Eat St. | | ||
- | |**Cause Team**. | Brendan Halliday (@nog3), Aaron Bycroft (@crofty) and Michael King (@doc) | | + | |**Cause Team** | Brendan Halliday (@nog3), Aaron Bycroft (@crofty) and Michael King (@doc) | |
|**Objective** | Digifab's goals are to provide and maintain equipment in the principles of digital fabrication, primarily 3D printing and laser cutting. | | |**Objective** | Digifab's goals are to provide and maintain equipment in the principles of digital fabrication, primarily 3D printing and laser cutting. | | ||
- | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] \\ [[https://discord.gg/z2sTZB|Discord Chat]] \\ [[https://trello.com/invite/b/ERpgbqEh/78075b9da25bd2e659c41640dd442b30/digifab|Trello Task Tracking]] | | + | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://trello.com/invite/b/ERpgbqEh/78075b9da25bd2e659c41640dd442b30/digifab|Trello Task Tracking]] | |
|**Operating Policy** | [[causes:digitalfabrication:operatingpolicy| Operating Policy should be split out into it's own page]] | | |**Operating Policy** | [[causes:digitalfabrication:operatingpolicy| Operating Policy should be split out into it's own page]] | | ||
- | ====== Digital Fabrication Cause ====== | ||
- | {{ :causes:digifab.jpg?nolink|}} | ||
- | <panel type="default" title=""> | ||
- | **Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | ||
- | **Cause Leader:** Cause Leader: Aaron Bycroft, aka "Crofty" | ||
- | **Recommended Suppliers**: [[https://wiki.hsbne.org/causes/digitalfabrication/suppliers|See here]]. | ||
- | **Operating Policy:** [[causes:digitalfabrication:operatingpolicy|Policy]] | ||
- | </panel> | ||
===== Cause Area Rules ===== | ===== Cause Area Rules ===== |
- causes/digitalfabrication.1603808556
- by jabelone
