Both sides previous revision
causes:electronics [2019/08/11 14:54] |
causes:electronics [2019/08/17 17:26] |
* Please don’t leave irons or other tools on when you’re not immediately using them. | * Please don’t leave irons or other tools on when you’re not immediately using them. |
* Please return tools to their homes. | * Please return tools to their homes. |
| ===== Cause Owned Equipment ===== |
| <nspages tools:electronics -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> |
===== Tools requiring Induction ===== | ===== Tools requiring Induction ===== |
- Spot Welder - | **Spot Welder -** |
* Induction process is to demonstrate safe use of the tool and then get them to try it also. | * Induction process is to demonstrate safe use of the tool and then get them to try it also. |
- Reflow Oven - | **Reflow Oven - ** |
* Induction process is to run through approved uses for the oven and how to achieve them and demonstrate use of front panel and default oven profiles. | * Induction process is to run through approved uses for the oven and how to achieve them and demonstrate use of front panel and default oven profiles. |
* Maintainers are Brendan (nog3) and Blair (merseyless) | * Maintainer is Lucas Oldfield (BadBiki) |
===== Tools requiring Supervision ===== | ===== Tools requiring Supervision ===== |
Currently none of our tools require supervision. | Currently none of our tools require supervision. |
===== Ongoing Budgets ===== | ===== Ongoing Budgets ===== |
Monthly Consumables Discretionary - $100. This is for reimbursing purchases of things required from the Electronics Cause Consumables list. | Monthly Consumables Discretionary - $100. This is for reimbursing purchases of things required from the Electronics Cause Consumables list. |
===== Current Goals ===== | ===== Current Goals ===== |
* To be held every (or every second) Saturday from midday till 1:30pm\\ | * To be held every (or every second) Saturday from midday till 1:30pm\\ |
* How to read schematics and construct circuits\\ | * How to read schematics and construct circuits\\ |
* Making a radio\\ | * Making a radio\\ |
* Basic electronic measurement and component characteristics\\ | * Basic electronic measurement and component characteristics\\ |
* Soldering class\\ | * Soldering class\\ |
* Oscilloscope measurement and basic AC circuits\\ | * Oscilloscope measurement and basic AC circuits\\ |
* Basic circuit analysis and component calculation\\ | * Basic circuit analysis and component calculation\\ |
* The transistor and you\\ | * The transistor and you\\ |
* Introduction to opamps\\ | * Introduction to opamps\\ |
* Introduction to 555 timer\\ | * Introduction to 555 timer\\ |
* Introduction to logic gates\\ | * Introduction to logic gates\\ |
* Introduction to microcontrollers\\ | * Introduction to microcontrollers\\ |
* The arduino, reading sensors\\ | * The arduino, reading sensors\\ |
* Remote reading and switching\\ | * Remote reading and switching\\ |
* Basic circuit troubleshooting\\ | * Basic circuit troubleshooting\\ |
* Electronic circuit strategy (building blocks of circuit design)\\ | * Electronic circuit strategy (building blocks of circuit design)\\ |
* Making a PCB\\ | * Making a PCB\\ |
* Designing a PCB\\ | * Designing a PCB\\ |
