causes:electronics [2019/06/08 17:05] |
causes:electronics [2021/12/31 15:47] (current) devians update discord link |
- | **Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | + | <panel> |
- | **Cause Leader:** Brendan (nog3) Halliday\\ | + | {{ : causes: electronics.jpg?direct&400|The electronics bench}} |
- | **Objective:** To provide an accessible electronics work-space that allows advanced electronic design to be conducted at HSBNE.\\ | + | <WRAP> |
- | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]]\\ | + | |**Location** | The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted. | |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | + | |**Cause Leader** | [[user:BadBiki|Lucas]] | |
+ | |**Objective** | To provide functional and professional electrical equipment for the development, debugging and assembly of electrical projects ranging in complexity and quality. From entry-level evaluation boards and Raspberry Pi's all the way up to PCB assembly and Reflow Soldering. | | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/electronics|Forum Category]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://trello.com/invite/b/EkFs17hM/cd4b100222e897de0db90a984a032509/electronics|Trello Task Tracking]] | | ||
+ | </panel> | ||
+ | * JST, Molex, AMP | ||
- | * Introduction to logic gates\\ | + | {{tag>electronics}} |
- | * Making a PCB\\ | + | |
- causes/electronics.1559977516
