causes:home [2020/09/01 21:00] jabelone |
causes:home [2020/09/01 21:08] (current) jabelone [Cause Leader Resources] |
Line 13: | Line 13: | ||
==== Cause Leader Resources ==== | ==== Cause Leader Resources ==== | ||
+ | The link below goes to the main ''Causes'' folder that is accessible by any cause leader and actively engaged member. If you don’t already have access please ask Jaimyn, Brendan, or the exec and we can add you. | ||
+ | In here you’ll find a folder for each cause which contains the cause operating policy, a folder called ''Tools'' and any other cause related documents. Things like induction scripts, tests, machine manuals, etc should go into this folder (make a new folder under ''Tools'' for each tool). | ||
+ | In the root ''Causes'' folder, you’ll find templates for the cause operating policy and JIT Documentation that would be great to see posted near each tool. | ||
+ | [[https://drive.google.com/drive/u/0/folders/1Qbo3y44I1GvxX0o006OI7Z4W0blIUJj_|Google Drive Causes Folder]] | ||
+ | You can add new tools to your cause area by using the form at the top of the [[https://wiki.hsbne.org/tools/home|Tools]] page. |
- causes/home.1598958052
- by jabelone
