causes:metalworking [2018/10/15 14:53]
causes:metalworking [2022/09/30 09:11] (current)
capella_ben
Line 1: Line 1:
-===== Cause Leader =====+====== Metalworking Team ======
 +<​panel>​
 +{{ : causes: metalshop.jpg?​direct&​400|The metal shop area}}
 +<​WRAP>​
 +| **Location** ​         | The Metal Shop is located in the big shed, on the left hand side when facing towards the road from inside the quad.        |
 +| **Cause Leader**      | Ryan Marple (@Ryan M)        |
 +| **Objective** ​        | To always maintain a work space environment with a high standard of safety and a respect for other members of HSBNE using the metal shop. This can be achieved through the cooperation and adhering to the policies, procedures and processes of the Metal Shop.  |
 +| **Current Goals** ​    | Restructure shop to be more usable. ​        |
 +| **Members** ​          | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] ​        |
 +| **Communications** ​   | [[https://​forum.hsbne.org/​c/​cause-effect/​metalworking|Forum Category]] \\ [[https://​chat.hsbne.org/​|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​rkCyfwbd/​26dc2c066dd645153560a41bbde70b88/​metalshop|Trello Task Tracking]] ​                                   |
 +| **Operating Policy** ​ | [[causes:​metalworking:​operatingpolicy|Policy]] ​        |
 +</​WRAP>​
 +===== Cause Area Expectations ​=====
 +* Think safety first. Wear correct PPE.\\
-**Drew Spriggs**+Plan your work piece and work steps. Check here or on Discord that the tools you need are in the shop.\\
-===== Members ===== +* Get inducted and double check work steps for safe practices.\\
-===== Equipment to be Purchased =====+
 +* Leave the area as clean or cleaner than you found it.\\
-===== Cleaning plan =====+* Only use tools in the way they are intended to be used.\\
-Each member will clean up after themselves. Cleanup during weekly meeting. +* Ask for help or guidance ​when you need it.\\
-===== Maintenance Plan ===== +
-Broken ​or tools needing maintenance to be marked with appropriate ticket. Consumables:​ each member supplies own consumables. +
-===== Classes ===== +
-To express interest in a class, please post in the forums and when we have a full class, they will run. +
-  * Welding +
-  * Basic turning+
 +* Respect that some members may not want to break their focus to talk or answer questions. The exception to this rule is in the case of dangerous or disrespectful tool use and emergencies.\\
 +===== Metalworking Tools =====
 +<nspages tools:​metalshop -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
 +</​panel>​
  • causes/metalworking.1539579231
  • Last modified: 4 years ago
  • (external edit)
