Next revision
causes:woodworking [2020/08/14 00:21]
causes:woodworking [2021/12/31 15:49] (current)
devians update discord link
Line 1: Line 1:
 ====== Woodworking Cause ====== ====== Woodworking Cause ======
-{{:​causes:​woodshop-room.jpg?​direct|The woodshop room as of 02/​02/​2019}}+{{ :​causes:​woodshop-room.jpg?​direct&600|The woodshop room as of 02/​02/​2019}}
 <​WRAP>​ <​WRAP>​
 |**Location** ​        | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | |**Location** ​        | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. |
-|**Cause Leader** ​    ​| ​Joshua Hogendorn ​|+|**Cause Leader** ​    ​| ​Ale MorĂ© |
 |**Objective** ​       | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | |**Objective** ​       | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. |
 |**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] | |**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] |
-|**Communications** ​  | [[https://​forum.hsbne.org/​c/​cause-effect/​woodworking|Forum Category]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​xmODU9ax/​e44742719bbd040c69a17dbfd8c9653f/​woodshop|Trello Task Tracking]] |+|**Communications** ​  | [[https://​forum.hsbne.org/​c/​cause-effect/​woodworking|Forum Category]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​xmODU9ax/​e44742719bbd040c69a17dbfd8c9653f/​woodshop|Trello Task Tracking]] |
 |**Operating Policy** | [[causes:​woodworking:​operatingpolicy| Operating Policy]] | |**Operating Policy** | [[causes:​woodworking:​operatingpolicy| Operating Policy]] |
  • causes/woodworking.1597328464
  • Last modified: 4 years ago
  • by devians
