Next revision
causes:woodworking [2020/08/13 23:59]
causes:woodworking [2021/12/31 15:49]
devians update discord link
Line 1: Line 1:
 ====== Woodworking Cause ====== ====== Woodworking Cause ======
-{{:​causes:​woodshop-room.jpg?​direct|The woodshop room as of 02/​02/​2019}}+{{ :​causes:​woodshop-room.jpg?​direct&600|The woodshop room as of 02/​02/​2019}}
 <​WRAP>​ <​WRAP>​
 |**Location** ​        | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | |**Location** ​        | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. |
-|**Cause Leader** ​    ​| ​Joshua Hogendorn ​|+|**Cause Leader** ​    ​| ​Ale MorĂ© |
 |**Objective** ​       | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | |**Objective** ​       | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. |
 |**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] | |**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] |
-|**Communications** ​  | [[https://​forum.hsbne.org/​c/​cause-effect/​woodworking|Forum Category]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​xmODU9ax/​e44742719bbd040c69a17dbfd8c9653f/​woodshop|Trello Task Tracking]] |+|**Communications** ​  | [[https://​forum.hsbne.org/​c/​cause-effect/​woodworking|Forum Category]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://​trello.com/​invite/​b/​xmODU9ax/​e44742719bbd040c69a17dbfd8c9653f/​woodshop|Trello Task Tracking]] |
 |**Operating Policy** | [[causes:​woodworking:​operatingpolicy| Operating Policy]] | |**Operating Policy** | [[causes:​woodworking:​operatingpolicy| Operating Policy]] |
Line 34: Line 34:
 ==== Consumables ==== ==== Consumables ====
-^ Category ^ Name/​Type/​Spec/​Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked+^ Category ^ Name/​Type/​Spec/​Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked ​^
 | Sandpaper | Belt 150x1220mm @P120 | Disc&​Belt Sander | 1 | 5 | 20 | | Sandpaper | Belt 150x1220mm @P120 | Disc&​Belt Sander | 1 | 5 | 20 |
 | Sandpaper | Disc 305mm @P120 | Disc&​Belt Sander, 12" Disc Sander | 2 | 10 | 40 | | Sandpaper | Disc 305mm @P120 | Disc&​Belt Sander, 12" Disc Sander | 2 | 10 | 40 |
Line 53: Line 53:
 | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 |
 | Blades | [[https://​www.bunnings.com.au/​craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 | | Blades | [[https://​www.bunnings.com.au/​craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 |
 +| Carbide | 07.0.020 10pc Carbide 13.8x13.8x2.5 mm | A3-31 | 0 | 10 | 10 |
 | Fasteners | Robertson 16mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | Fasteners | Robertson 16mm | General Purpose | 1 Pack | 2 Packs | 10 Packs |
 | Fasteners | Robertson 22mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | Fasteners | Robertson 22mm | General Purpose | 1 Pack | 2 Packs | 10 Packs |
  • causes/woodworking
  • Last modified: 2 years ago
  • by devians
