contacts [2021/01/06 17:00] jabelone [Reporting A Problem] |
contacts [2023/11/02 17:54] rhinocnc [Who to contact at HSBNE.] |
====== Who to contact at HSBNE. ====== | ====== Who to contact at HSBNE. ====== | ||
- | For anything to do with how HSBNE runs on a day to day basis, outside of cause areas, you should email the Executive on [[exec@hsbne.org]]. | + | For anything to do with how HSBNE runs on a day to day basis, outside of cause areas, you should email the Executive on [serena2009@rhinocnclaser.com]. |
**Individual roles of the exec are:** | **Individual roles of the exec are:** | ||
^ Position ^ Name ^ Discord ^ Email ^ | ^ Position ^ Name ^ Discord ^ Email ^ | ||
- | | President | Joshua Hogendorn | @devians | president@hsbne.org | | + | | President | Murray Wayper | @Antifoo | president@hsbne.org | |
- | | Vice President | Eris Ryan | @Eris | vicepresident@hsbne.org | | + | | Treasurer | Joshua Hogendorn | @devians | treasurer@hsbne.org | |
- | | Treasurer | Ian Redmond | @roving | treasurer@hsbne.org | | + | | Secretary | Scott Wilson | @Siridar | secretary@hsbne.org | |
- | | Secretary | Emily Taylor | @Pommygirl | secretary@hsbne.org | | + | |
- | | Patron | Dave Seff | @moltenaluminium | patron@hsbne.org | | + | |
For anything to do with cause areas, please post in the relevant discord channel or contact a member of the cause leader team (which can be found on each cause's wiki page). | For anything to do with cause areas, please post in the relevant discord channel or contact a member of the cause leader team (which can be found on each cause's wiki page). | ||
===== Reporting A Problem ===== | ===== Reporting A Problem ===== | ||
- | You can report an issue in the membership portal [[https://portal.hsbne.org/tools/issue/|here]] if you can't work out who to ask for help, find a broken tool, or find something that someone needs to know about. Alternatively, you can send an email to issues@hsbne.org. | + | You can report an issue in the membership portal [[https://portal.hsbne.org/tools/issue/|here]] if you can't work out who to ask for help, find a broken tool, or find something that someone needs to know about. Alternatively, you can send an email to [[issues@hsbne.org]]. |
===== Digital Infrastructure Issues ===== | ===== Digital Infrastructure Issues ===== | ||
- | If there's anything wrong with the digital infrastructure, let us know in the **#infrastructure** channel on Discord or by email to [[mailto:infrastructure@hsbne.org|infrastructure@hsbne.org]]. You can also report an issue in the membership portal [[https://portal.hsbne.org/tools/issue/|here]]. | + | If there's anything wrong with the digital infrastructure (like our access system, member portal, etc.), let us know in the **#infrastructure** channel on Discord or by email to [[mailto:infrastructure@hsbne.org|infrastructure@hsbne.org]]. You can also report an issue in the membership portal [[https://portal.hsbne.org/tools/issue/|here]]. |
- contacts
- Last modified: 7 months ago
- by rhinocnc
