projects:catprog:solarboiler [2020/04/11 12:01] 127.0.0.1 external edit |
— (current) | ||
- | As part of my solar airconditioner I am working on a project to use the sun to boil water. | ||
- | V2 is a $5 kmart glass jar with a water bottle inside. This is surrounded by a reflector. | ||
- | {{:projects:catprog:20190824_163218.jpg?400|}} | ||
- | **Key Discoveries:** | ||
- | The glass jar does not get hot despite being in the sun. | ||
- | The drink bottle is almost boiling the water. | ||
- | **31 Aug 2019 log** | ||
- | I started with 800ml of cold water. | ||
- | At the end of the day I had 740ml of almost boiling water. | ||
- | ** 9 Dec 2019 ** | ||
- | I have decided to go with a flat panel design to get more energy. | ||
- | However my solar collector pipe has sprung a number of leaks. | ||
- | ** 8 March 2020** | ||
- | After a lot of research I have found that the water only needs to get to 50C and not boiling. The new design is to lay a number of coils of black pipe on the roof to get the heat. And even on a cloudy day the water gets to a reasonable temperature. | ||
- | Now I just need to add more coils to get the temperature up higher and build a way to get it back down to ambient. |
- projects/catprog/solarboiler.1586570496
- by 127.0.0.1
