tools:digitalfabrication:3dprinters:home [2020/12/30 15:17] jabelone |
tools:digitalfabrication:3dprinters:home [2021/11/18 18:21] jdownie [Individual Printer Pages & Other Resources] |
Line 2: | Line 2: | ||
{{:tools:digitalfabrication:3dprinters:printers.jpg?nolink&400|}} | {{:tools:digitalfabrication:3dprinters:printers.jpg?nolink&400|}} | ||
- | PLA is the most brittle and weak of filaments and also has a fairly low glass transition temperature of around 60 degrees. PLA is recommended for it's ease of printing whenever you don't need the strength or heat resistance of PETG. | + | We do not recommend people print unless the specifics of the material behaviour are known and needed. ABS can be strong, has some flexibility, and has higher heat tolerance with a glass transition temperature of around 100 degrees. Variants such as ABS+ or ABSmax (from eSun) can be very easy to print with some practice, although the filaments can cost more than PETG and even high quality PLA variants. ABS can also release styrene when printing, which may give some people headaches or other ill feelings when exposed for extended periods. ABS is not UV stable, so printed objects used outdoors may degrade over time. Many ABS variants have the advantage of being able to be welded or vapour smoothed using acetone. |
+ | ==== ASA ==== | ||
- | <del> | ||
- by bwilkins
