tools:digitalfabrication:3dprinters:home [2020/12/30 17:25] jabelone [HSBNE 3D Printer Design Tips] |
tools:digitalfabrication:3dprinters:home [2023/04/26 05:17] bwilkins [3D Printers] |
===== Want to get started printing quickly? ===== | ===== Want to get started printing quickly? ===== | ||
Line 13: | Line 13: | ||
- | PLA is the most brittle and weak of filaments (comparatively) and also has a fairly low glass transition temperature of around 60 degrees. However, don't think PLA is weak or bad to print with, it's most suited to models like figurines etc. due to the ease of printing. PLA *will* melt if left in a really hot area like a car. PLA is recommended for it's ease of printing whenever you don't need the strength or heat resistance of PETG. | + | We do not recommend people print unless the specifics of the material behaviour are known and needed. ABS can be strong, has some flexibility, and has higher heat tolerance with a glass transition temperature of around 100 degrees. Variants such as ABS+ or ABSmax (from eSun) can be very easy to print with some practice, although the filaments can cost more than PETG and even high quality PLA variants. ABS can also release styrene when printing, which may give some people headaches or other ill feelings when exposed for extended periods. ABS is not UV stable, so printed objects used outdoors may degrade over time. Many ABS variants have the advantage of being able to be welded or vapour smoothed using acetone. |
+ | ==== ASA ==== | ||
===== 3D Printer Maintainers ===== | ===== 3D Printer Maintainers ===== | ||
Line 49: | Line 52: | ||
Try not to leave any debris or print detritus around the printers too, as they may get caught up in the mechanical parts, and mess attracts more mess. | Try not to leave any debris or print detritus around the printers too, as they may get caught up in the mechanical parts, and mess attracts more mess. | ||
===== Individual Printer Pages & Other Resources ===== | ===== Individual Printer Pages & Other Resources ===== | ||
- | To get started printing something, you must read the printer's individual page *in full*. Please don't try to just "work it out" or you can damage the machine. | + | |
<nspages -exclude:home -usePictures -h1 -textNS="" -subns -pagesInNs -naturalOrder> | <nspages -exclude:home -usePictures -h1 -textNS="" -subns -pagesInNs -naturalOrder> |
- by bwilkins
