tools:electronics:soldering [2019/07/19 18:58] |
tools:electronics:soldering [2020/09/16 17:21] catprog Start of instructions. |
Line 7: | Line 7: | ||
We have two of these stations with SHP-K handpieces. It takes the K type Thermaltronics tips. | We have two of these stations with SHP-K handpieces. It takes the K type Thermaltronics tips. | ||
+ | To Use: | ||
+ | 1)Make sure the black button up top is down. | ||
+ | 2)The black switch below is set to the correct socket | ||
+ | 3)Lift the soldering iron out of the holder | ||
+ | 4)Make sure the light turns yellow. | ||
+ | To change tips | ||
+ | 1) Turn off the soldering iron | ||
+ | 2)Use the silicon pad to pull the tip out | ||
+ | 3) Insert new tip | ||
+ | 4) Turn soldering iron on and make sure the light turns yellow. | ||
====== Metcal PS-200 Soldering Iron ====== | ====== Metcal PS-200 Soldering Iron ====== | ||
+ | {{tag>electronics}} | ||
- tools/electronics/soldering
- by catprog
