tools:home [2019/07/19 18:48] |
- | ==== Areas ==== | + | ===== Add New Tool ===== |
- | === Classroom === | + | Any registered wiki user can create a new tool page by using the form below (only visible to logged in users). Just select the cause area, enter the name of the tool, then click "Add page". |
- | <nspages tools:classroom -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | + | |
- | === Craft Punk === | + | {{NEWPAGE>tools}} |
- | <nspages tools:craftpunk -subns -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | + | |
- | ==== Digital Fabrication ==== | + | |
- | Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | + | |
- | <nspages tools:digitalfabrication -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | + | |
- | === Green Room === | + | \\ 1) Login using your HSBNE Wiki account (contact @infrastructure on discord if you have any problems). |
- | <nspages tools:greenroom -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | + | |
- | === Electronics Bench === | + | |
- | <nspages tools:electronics -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | + | |
- | === Forge === | + | 2) Check this list to make sure the page you want to add doesn't already exist. |
- | <nspages tools:forge -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | + | |
- | <nspages tools:metalshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | + | |
- | === Wood Shop === | + | |
- | <nspages tools:woodshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | + | |
+ | Overseen by the [[causes/metalworking|MetalShop Team]]. <nspages tools:metalshop -exclude:home -exclude:yaglaser -exclude:wip: -exclude:handtools: -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
