tools:home [2019/07/19 17:10] |
- | <nspages -subns -h1 -exclude -simplelist> | + | ===== HSBNE Tools ===== |
+ | This page lists the various tools and machines available for HSBNE members to use. Laser Cutters, 3d Printers, Mills, Lathes, Saws, etc.; it all goes here. This page is grouped by HSBNE cause areas. The standard template for adding new tool pages can be found [[tools:template|here]]. | ||
+ | ===== Add New Tool ===== | ||
+ | {{NEWPAGE>tools}} | ||
+ | \\ 1) Login using your HSBNE Wiki account (contact @infrastructure on discord if you have any problems). | ||
+ | Overseen by the [[causes/metalworking|Metal Shop Team]]. <nspages tools:metalshop -exclude:home -exclude:yaglaser -exclude:wip: -exclude:handtools: -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
