tools:metalshop:3axismill [2021/01/01 22:29] ryan6338 |
Line 32: | Line 23: | ||
+ | ===== Learning ===== | ||
- | | Required | {{:resources:ppe-weargoggle.gif?nolink&100|}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | | + | | Required | {{ :resources:ppe-wearsafetyglasses.gif?nolink&100 |}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | |
- | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&100|}} | Enclosed shoes are required, no open sandals, thongs etc | | + | | Required | {{ :resources:ppe-wearenclosedshoes.gif?nolink&100 |}} | Enclosed shoes are required, no open sandals, thongs etc | |
- | | Recommended | {{:resources:ppe-wearearprotection.gif?nolink&100|}} | We recommend hearing protection. | | + | | Required | {{ :resources:ppe-hair.gif?nolink&100 |}} | Restrain hair while operating machine | |
- | | Warning | {{:resources:ppe-wearhandprotection.gif?nolink&100|}} | Entanglement hazard present while wearing gloves. | | + | | Recommended | {{ :resources:ppe-wearearprotection.gif?nolink&100 |}} | We recommend hearing protection. | |
- | | Maintenance | {{:resources:ppe-disconnect.gif?nolink&100|}} | Disconnect power to the machine before performing maintenance, including wheel changes | | + | | Warning | {{ :resources:ppe-wearhandprotection.gif?nolink&100 |}} | Entanglement hazard present while wearing gloves. | |
Line 56: | Line 60: | ||
- | === Reseller === | + | |
- | * Mr. Re seller | + | |
Line 132: | Line 129: | ||
- tools/metalshop/3axismill
