tools:metalshop:3axismill [2021/01/07 08:45] ryan6338 [Personal Protective Equipment] |
- | === Working === | ||
+ | === Working === | ||
+ | </WRAP>*/ | ||
+ | === Usable === | ||
+ | </WRAP>*/ | ||
+ | === Out of Order === | ||
Line 32: | Line 34: | ||
+ | ===== Learning ===== | ||
Line 40: | Line 53: | ||
| Required | {{ :resources:ppe-wearenclosedshoes.gif?nolink&100 |}} | Enclosed shoes are required, no open sandals, thongs etc | | | Required | {{ :resources:ppe-wearenclosedshoes.gif?nolink&100 |}} | Enclosed shoes are required, no open sandals, thongs etc | | ||
| Required | {{ :resources:ppe-hair.gif?nolink&100 |}} | Restrain hair while operating machine | | | Required | {{ :resources:ppe-hair.gif?nolink&100 |}} | Restrain hair while operating machine | | ||
Line 57: | Line 71: | ||
- | === Reseller === | + | |
- | * Mr. Re seller | + | |
Line 133: | Line 140: | ||
- tools/metalshop/3axismill
