tools:metalshop:3axismill [2021/10/06 21:20] ryan6338 [Documents] |
- | | Official Maintainer | Lincoln | | + | |
- | === Working === | ||
+ | === Working === | ||
+ | </WRAP>*/ | ||
+ | === Usable === | ||
+ | </WRAP>*/ | ||
+ | === Out of Order === | ||
Line 32: | Line 34: | ||
- | Book an induction in Eventbrite. \\ [[https://www.eventbrite.com/d/australia--south-brisbane/mill-induction-(hsbne-members-only)/]] | + | Book an induction in Eventbrite. \\ [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] |
+ | ===== Learning ===== | ||
Line 57: | Line 71: | ||
- | No documents are currently available for this machine. | + | <WRAP center round download third left> |
- | ===== Manufacturer ===== | + | {{ :tools:metalshop:mill_dro_manual.pdf |}} |
- | PLACEHOLDER: Document the manufacturer, things like contact person names, emails, phone numbers, product urls etc. Document the reseller we bought from, and any other sources for similar things. Delete this line. | + | <WRAP clear></WRAP> |
- | === Manufacturer === | + | ===== Manufacturer ===== |
- | * E sales@example.com | ||
- | * P 00 0000 0000 | ||
- | * [[https://www.example.com/]] | ||
- | === Reseller === | + | === Manufacturer === |
- | * Mr. Re seller | + | * The Pacific Mill is a renamed Lagun |
- | * Reseller Agencies | + | * [[https://lagun.com]] |
Line 127: | Line 140: | ||
- tools/metalshop/3axismill
capella_ben
