tools:metalshop:3axismill [2021/01/07 09:15] ryan6338 |
tools:metalshop:3axismill [2023/07/19 08:11] (current) capella_ben [Current Status] |
- | === Working === | ||
+ | === Working === | ||
+ | </WRAP>*/ | ||
+ | === Usable === | ||
+ | </WRAP>*/ | ||
+ | === Out of Order === | ||
Line 32: | Line 34: | ||
+ | ===== Learning ===== | ||
Line 58: | Line 71: | ||
- | === Reseller === | + | |
- | * Mr. Re seller | + | |
Line 134: | Line 140: | ||
- tools/metalshop/3axismill.1609974924
ryan6338
