tools:metalshop:bandsaw [2021/10/06 13:38] ryan6338 |
tools:metalshop:bandsaw [2023/03/07 20:05] (current) capella_ben [Usage] |
Line 4: | Line 4: | ||
====== Bandsaw, Horizontal - Hafco BS-7DS ====== | ====== Bandsaw, Horizontal - Hafco BS-7DS ====== | ||
- | | Aliases | - | | + | | Aliases | - | |
- | | Official Maintainer | Dave Seff | | + | |
<WRAP safety half round> | <WRAP safety half round> | ||
=== Working === | === Working === | ||
Machine is working as expected. | Machine is working as expected. | ||
+ | === Usable === | ||
+ | </WRAP>*/ | ||
+ | /*<WRAP danger half round> | ||
+ | === Out of Order === | ||
+ | Machine is non functional. | ||
+ | </WRAP>*/ | ||
Line 31: | Line 31: | ||
- | Book an induction in Eventbrite. \\ [[https://www.eventbrite.com/d/australia--south-brisbane/hsbne-inc-bandsaw/?page=1]] | + | Book an induction in Eventbrite. \\ [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] |
- | ==== Personal Protective Equipment ==== | + | |
+ | This machine is a part of the Drill Press, Linishers and Vertical bandsaw induction. | ||
+ | ===== Personal Protective Equipment ===== | ||
Line 57: | Line 64: | ||
| Weight | 165kg | | | Weight | 165kg | | ||
- | ===== Guidelines ===== | + | ===== Documents ===== |
- | === Blade Adjustment guide === | + | <WRAP center round download third left> |
- | + | {{ :tools:metalshop:b008a_-_instruction_manual.pdf | Manual }} | |
- | This gives a reasonable explanation of how to adjust the blade. If you find it cutting out of square, please discuss this with the cause leader for calibration. | + | </WRAP> |
- | + | <WRAP clear></WRAP> | |
- | {{:tools:4x6bandsawadjust.pdf|}} | + | <WRAP center round download third left> |
- | + | {{ :tools:4x6bandsawadjust.pdf | Blade Adjustment Guide }} | |
+ | <WRAP clear></WRAP> | ||
===== Supplier ===== | ===== Supplier ===== | ||
Line 73: | Line 81: | ||
+ | | 9/8/2022 | Main On/Off Sitch failure | None | Replace the switch - Electrician required | | ||
+ | | 9/8/2022 | Interlock Failure | Interlock has been disabled | Replace the interlock microprocessor board | | ||
Line 82: | Line 92: | ||
| 08/12/2020 | Ryan Marple | All bandsaw blades dull | Purchased 2 new bi-metal blades | $110 | | | 08/12/2020 | Ryan Marple | All bandsaw blades dull | Purchased 2 new bi-metal blades | $110 | | ||
| 08/12/2020 | Ryan Marple | Fasteners holding cover require different tools to open | Replaced fasteners with wing screws | $20 | | | 08/12/2020 | Ryan Marple | Fasteners holding cover require different tools to open | Replaced fasteners with wing screws | $20 | | ||
+ | | 04/01/2022 | Dave Seff | Repaired water damaged interlock | Replaced contactor | $70 | | ||
Line 122: | Line 133: | ||
- | ^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||| | + | ^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||| |
- | | ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level | ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ | + | | ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level | ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ |
- | | 0001 | Projectile | Intolerable | Probable | 12 | Induction required. \\ Require use of appropriate PPE. | Low | Possible | 2 | Yes | | + | | 0001 | Death | Severe | Possible | 15 | Induction to train users in correct usage. | Severe | Very Unlikely | 5 | Yes | |
- | | 0002 | Entanglement | Intolerable | Probable | 12 | Induction required. \\ Discourage glove use during operation. \\ Prohibit long hair & jewellery. | Low | Possible | 2 | Yes | | + | | 0002 | Electric Shock | Major | Unlikely | 8 | Induction to train users in correct usage.\\ Ensure power cables are properly connected and off the floor.\\ Cables are tested and tagged and inspected for damage. | Minor | Very Unlikely | 2 | Yes | |
- | | 0003 | Laceration/Dismemberment | Intolerable | Possible | 11 | Induction required. \\ Require use of appropriate PPE. | Low | Improbable | 1 | Yes | | + | | 0003 | Noise | Moderate | Likely | 12 | Train users to wear hearing protection. | Insignificant | Unlikely | 2 | Yes | |
- | | 0004 | Heat burn from workpiece | Undesirable | Possible | 8 | Induction required.\\ Always ensure coolant is working properly.\\ Feel workpiece temperature before grabbing it. | Low | Improbable | 1 | Yes | | + | | 0004 | Tripping Hazard | Moderate | Possible | 9 | Train users to maintain a clean working area.\\ Keep all cables off the ground and secured out of the way. | Insignificant | Unlikely | 2 | Yes | |
+ | | 0007 | Slip | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users in correct use of coolant to avoid spilling on the floor. | Minor | Unlikely | 4 | Yes | | ||
+ | | 0008 | Respiratory/Skin Irritation | Moderate | Unlikely | 6 | Induction to train users in correct usage.\\ Train users in the risks related to metalworking fluids. | Minor | Unlikely | 4 | Yes | | ||
+ | | 0009 | Inhaliation of Fumes | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Open metal-shop door to allow ventilation.\\ Fans are provided top assist in ventilation. \\ Train users to use the appropriate type and volume of coolant.\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | | ||
+ | | 0010 | Laceration/Dismemberment | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users to keep clear of the cutting tool and the part.\\ Require that the cutting tool is securely fixed (in the quick change tool-post or tail-stock).\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | | ||
+ | | 0011 | Burn from workpiece | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Allow parts to cool after cutting.\\ Train users to ensure adequate coolant is used.\\ Require assessing workpiece temperature before handling. | Insignificant | Unlikely | 2 | Yes | | ||
- tools/metalshop/bandsaw.1633491529
- by ryan6338
