tools:metalshop:bandsaw [2022/09/16 13:22] capella_ben [Table] |
tools:metalshop:bandsaw [2023/03/07 20:05] (current) capella_ben [Usage] |
Line 12: | Line 12: | ||
- | /*<WRAP safety half round> | + | <WRAP safety half round> |
=== Working === | === Working === | ||
Machine is working as expected. | Machine is working as expected. | ||
- | </WRAP>*/ | + | </WRAP> |
/*<WRAP warning half round> | /*<WRAP warning half round> | ||
Machine has some issue but is usable. please provide summary here | Machine has some issue but is usable. please provide summary here | ||
</WRAP>*/ | </WRAP>*/ | ||
- | <WRAP danger half round> | + | /*<WRAP danger half round> |
=== Out of Order === | === Out of Order === | ||
- | Machine is non functional, as the starting switch has failed. | + | Machine is non functional. |
- | + | </WRAP>*/ | |
- | Ben Jackson 9/8/2022 | + | |
- | </WRAP> | + | |
Line 36: | Line 34: | ||
This machine is a part of the Drill Press, Linishers and Vertical bandsaw induction. | This machine is a part of the Drill Press, Linishers and Vertical bandsaw induction. | ||
- | ==== Personal Protective Equipment ==== | + | |
+ | ===== Personal Protective Equipment ===== | ||
Line 140: | Line 143: | ||
| 0007 | Slip | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users in correct use of coolant to avoid spilling on the floor. | Minor | Unlikely | 4 | Yes | | | 0007 | Slip | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users in correct use of coolant to avoid spilling on the floor. | Minor | Unlikely | 4 | Yes | | ||
| 0008 | Respiratory/Skin Irritation | Moderate | Unlikely | 6 | Induction to train users in correct usage.\\ Train users in the risks related to metalworking fluids. | Minor | Unlikely | 4 | Yes | | | 0008 | Respiratory/Skin Irritation | Moderate | Unlikely | 6 | Induction to train users in correct usage.\\ Train users in the risks related to metalworking fluids. | Minor | Unlikely | 4 | Yes | | ||
- | | 0009 | Inhaliation of Fumes | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Open metal-shop door to allow ventilation.\\ Train users to use the appropriate type and volume of coolant.\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | | + | | 0009 | Inhaliation of Fumes | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Open metal-shop door to allow ventilation.\\ Fans are provided top assist in ventilation. \\ Train users to use the appropriate type and volume of coolant.\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | |
| 0010 | Laceration/Dismemberment | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users to keep clear of the cutting tool and the part.\\ Require that the cutting tool is securely fixed (in the quick change tool-post or tail-stock).\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | | | 0010 | Laceration/Dismemberment | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users to keep clear of the cutting tool and the part.\\ Require that the cutting tool is securely fixed (in the quick change tool-post or tail-stock).\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | | ||
| 0011 | Burn from workpiece | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Allow parts to cool after cutting.\\ Train users to ensure adequate coolant is used.\\ Require assessing workpiece temperature before handling. | Insignificant | Unlikely | 2 | Yes | | | 0011 | Burn from workpiece | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Allow parts to cool after cutting.\\ Train users to ensure adequate coolant is used.\\ Require assessing workpiece temperature before handling. | Insignificant | Unlikely | 2 | Yes | |
- tools/metalshop/bandsaw.1663298560
