tools:metalshop:linisher [2021/01/01 22:27] ryan6338 |
tools:metalshop:linisher [2023/06/28 08:51] capella_ben [Manufacturer] |
Line 3: | Line 3: | ||
Line 29: | Line 20: | ||
**This machine <wrap hi>requires induction</wrap> to use.** | **This machine <wrap hi>requires induction</wrap> to use.** | ||
- | Request an induction in the metalshop channel on the HSBNE discord server, or create a post in the metalworking section of the forums. Inductions typically run on Tuesday nights, but alternative times can be arranged upon request. | + | Book an induction on Eventbrite.\\ |
+ | [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] | ||
- | | Required | {{:resources:ppe-weargoggle.gif?nolink&100|}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | | + | | Required | {{ :resources:ppe-wearsafetyglasses.gif?nolink&100 |}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | |
- | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&100|}} | Enclosed shoes are required, no open sandals, thongs etc | | + | | Required | {{ :resources:ppe-wearenclosedshoes.gif?nolink&100 |}} | Enclosed shoes are required, no open sandals, thongs etc | |
- | | Recommended | {{:resources:ppe-wearearprotection.gif?nolink&100|}} | We recommend hearing protection. | | + | | Required | {{ :resources:ppe-hair.gif?nolink&100 |}} | Restrain hair while operating machine | |
- | | Recommended | {{:resources:ppe-wearrespirator.gif?nolink&100|}} | We recommend the use of a respirator | | + | | Recommended | {{ :resources:ppe-wearearprotection.gif?nolink&100 |}} | We recommend hearing protection. | |
- | | Warning | {{:resources:ppe-wearhandprotection.gif?nolink&100|}} | Entanglement hazard present while wearing gloves. | | + | | Recommended | {{ :resources:ppe-wearrespirator.gif?nolink&100 |}} | We recommend the use of a respirator | |
- | | Maintenance | {{:resources:ppe-disconnect.gif?nolink&100|}} | Disconnect power to the machine before performing maintenance, including wheel changes | | + | | Warning | {{ :resources:ppe-wearhandprotection.gif?nolink&100 |}} | Entanglement hazard present while wearing gloves. | |
Line 78: | Line 73: | ||
Line 127: | Line 118: | ||
Line 138: | Line 138: | ||
- tools/metalshop/linisher
