tools:metalshop:linisher [2021/01/07 08:55] ryan6338 [Personal Protective Equipment] |
tools:metalshop:linisher [2023/06/28 08:56] capella_ben [Table] |
Line 3: | Line 3: | ||
Line 29: | Line 20: | ||
**This machine <wrap hi>requires induction</wrap> to use.** | **This machine <wrap hi>requires induction</wrap> to use.** | ||
- | Request an induction in the metalshop channel on the HSBNE discord server, or create a post in the metalworking section of the forums. Inductions typically run on Tuesday nights, but alternative times can be arranged upon request. | + | Book an induction on Eventbrite.\\ |
+ | [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] | ||
- | | Required | {{ :resources:ppe-weargoggle.gif?nolink&100 |}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | | + | | Required | {{ :resources:ppe-wearsafetyglasses.gif?nolink&100 |}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | |
| Required | {{ :resources:ppe-wearenclosedshoes.gif?nolink&100 |}} | Enclosed shoes are required, no open sandals, thongs etc | | | Required | {{ :resources:ppe-wearenclosedshoes.gif?nolink&100 |}} | Enclosed shoes are required, no open sandals, thongs etc | | ||
| Required | {{ :resources:ppe-hair.gif?nolink&100 |}} | Restrain hair while operating machine | | | Required | {{ :resources:ppe-hair.gif?nolink&100 |}} | Restrain hair while operating machine | | ||
Line 50: | Line 43: | ||
Line 80: | Line 73: | ||
- | | PLACEHOLDER Image, 100 width | PLACEHOLDER Category of consumable | **PLACEHOLDER Consumable Name** \\ PLACEHOLDER Consumable description and usage | PLACEHOLDER Description of where the consumable is stored | PLACEHOLDER Link to where it can be bought | | + | | | Grinding Wheel | [[https://www.totaltools.com.au/124868-norton-150-x-20mm-60-grit-medium-fine-grey-aluminium-oxide-grinding-wheel-66253130583|150mm x 20mm (not 25mm) Grinding Wheel]] | | Total Tools | |
Line 129: | Line 119: | ||
Line 140: | Line 139: | ||
- tools/metalshop/linisher
