tools:metalshop:linisher [2022/09/14 09:29] capella_ben [Table] |
Line 3: | Line 3: | ||
Line 51: | Line 43: | ||
Line 81: | Line 73: | ||
Line 98: | Line 90: | ||
+ | | {{:tools:metalshop:150mm_grinding_wheel.png|}} | Grinding Wheel | [[https://www.totaltools.com.au/124868-norton-150-x-20mm-60-grit-medium-fine-grey-aluminium-oxide-grinding-wheel-66253130583|150mm x 20mm (not 25mm) Grinding Wheel]] | | Total Tools | | ||
Line 126: | Line 119: | ||
- | ^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||| | + | ^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||| |
- | | ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level | ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ | + | | ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level | ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ |
- | | 0001 | PROJECTILE | Intolerable | Probable | 8 | Induction to train users in correct usage. \\ Require use of appropriate PPE. | Low | Possible | 2 | | | + | | 0001 | Death | Severe | Possible | 15 | Induction to train users in correct usage. | Severe | Very Unlikely | 5 | Yes | |
- | | 0002 | ENTANGLEMENT | Intolerable | Probable | 8 | Induction to train users in correct usage. \\ Discourage Glove Use | Low | Possible | 2 | | | + | | 0002 | Electric Shock | Major | Unlikely | 8 | Induction to train users in correct usage.\\ Ensure power cables are properly connected and off the floor.\\ Cables are tested and tagged and inspected for damage. | Minor | Very Unlikely | 2 | Yes | |
- | | 0003 | Dust Inhalation - Low-hazard materials | Undesirable | Probable | 8 | Provide dust extraction & encourage respirator use. | Tolerable | Improbable | 4 | | | + | | 0003 | Noise | Moderate | Likely | 12 | Train users to wear hearing protection. | Insignificant | Unlikely | 2 | Yes | |
- | | 0004 | Dust Inhalation - Hazardous materials | Intolerable | Probable | 8 | Restrict allowed grinding materials | Undesirable | Improbable | 6 | | | + | | 0004 | Tripping Hazard | Moderate | Possible | 9 | Train users to maintain a clean working area.\\ Keep all cables off the ground and secured out of the way. | Insignificant | Unlikely | 2 | Yes | |
- tools/metalshop/linisher
