tools:woodshop:tablesaws [2021/02/15 20:06] ale |
- | ~~notoc~~ | + | ~~TOC 1-4~~ |
Line 23: | Line 14: | ||
Line 31: | Line 22: | ||
- | ~~TOC_HERE 2-3~~ | + | |
====Induction=== | ====Induction=== | ||
<WRAP round info 50%> | <WRAP round info 50%> | ||
Line 40: | Line 31: | ||
- | Induction process is the completion of online courses and a 15min in-person physical evaluation. | + | Induction process is completion of online courses and a 15min in person physical evaluation. |
- [[https://canvas.instructure.com/enroll/T64LHC|ENROLL in the Metal Detection Course]]. 100% required pass. | - [[https://canvas.instructure.com/enroll/T64LHC|ENROLL in the Metal Detection Course]]. 100% required pass. | ||
Line 97: | Line 88: | ||
Line 103: | Line 94: | ||
Line 110: | Line 101: | ||
Line 131: | Line 122: | ||
Line 182: | Line 175: | ||
- tools/woodshop/tablesaws.1613383579
