tools:woodshop:tablesaws [2021/09/19 12:58] ale [Table] |
Line 122: | Line 122: | ||
Line 174: | Line 176: | ||
====Sharpening log==== | ====Sharpening log==== | ||
- | ^ Date ^ Blade ^ Notes ^ | + | ^ Date ^ Blade ^ Notes ^ |
- | | 13/09/2021 | TCG Acrylic | Sharpen by Brisbane Saw Services | | + | | 13/09/2021 | TCG Acrylic | Sharpen by Brisbane Saw Services | |
- tools/woodshop/tablesaws.1632020285
