tools:woodshop:tablesaws [2022/02/26 15:40] ale [Modifications / Repair History] |
Line 122: | Line 122: | ||
- | | 14/02/2021 | Ryan Marple & Ale Moré | The stops couldn't be calibrated with ease | Crosscut endstops were modified with an adjustable bullseye | -| | + | | 14/02/2021 | Ryan Marple & Ale Moré | The stops couldn't be calibrated with ease | Crosscut endstops were modified with an adjustable bullseye | - | |
- tools/woodshop/tablesaws.1645854054
