tools [2018/07/08 20:23] |
tools [2019/07/17 15:08] |
===== Areas ===== | ===== Areas ===== | ||
- | Overseen by the [[craftpunk|Craft Punk Cause]]. | + | Overseen by the [[causes/craftpunk|Craft Punk Cause]]. |
* [[Tools:HeatPress|Heat Presses]] | * [[Tools:HeatPress|Heat Presses]] | ||
* [[Tools:SewingMachines|Sewing Machines]] | * [[Tools:SewingMachines|Sewing Machines]] | ||
Line 11: | Line 11: | ||
* [[Tools:DesktopCNC|Desktop CNC]] | * [[Tools:DesktopCNC|Desktop CNC]] | ||
- | Overseen by the [[digitalfabrication|Digital Fabrication Cause]]. | + | Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. |
* [[Tools:3dprinters|3D Printers]] | * [[Tools:3dprinters|3D Printers]] | ||
- | * [[Tools:LaserCutter|Laser Cutter]] | + | * [[Tools:3dresinprinters|Resin 3D Printer(s)]] |
+ | * [[Tools:LaserCutter|Red Laser Cutter]] | ||
* [[Tools:3Dscanner|3D Scanner Turntable]] | * [[Tools:3Dscanner|3D Scanner Turntable]] | ||
- | * Large format printer | + | |
- | * Filastruder 3D printer filament extruder & recycler | + | |
* [[Tools:GreenRoomTV|Green Room TV]] | * [[Tools:GreenRoomTV|Green Room TV]] | ||
* [[Tools:GreenRoomHandTools|Green Room Hand Tools]] | * [[Tools:GreenRoomHandTools|Green Room Hand Tools]] | ||
- | Overseen by the [[electronics|Electronics Cause]]. | + | Overseen by the [[causes/electronics|Electronics Cause]]. |
* [[Tools:Desoldering|Desoldering Tools]] | * [[Tools:Desoldering|Desoldering Tools]] | ||
* [[Tools:FunctionGenerators|Function Generators]] | * [[Tools:FunctionGenerators|Function Generators]] | ||
Line 32: | Line 32: | ||
* [[Tools:LabelMakers|Label Makers]] | * [[Tools:LabelMakers|Label Makers]] | ||
- | Overseen by the [[metalworking|Machine Shop Cause]]. | + | Overseen by the [[causes/metalworking|Machine Shop Cause]]. |
* [[Tools:superstack|Superstack Speaker]] | * [[Tools:superstack|Superstack Speaker]] | ||
* [[Tools:okadavm500cncmill|Okada VM500 CNC Mill]] | * [[Tools:okadavm500cncmill|Okada VM500 CNC Mill]] | ||
Line 45: | Line 45: | ||
* [[Tools:Linisher|Linishers (grinder and belt sander)]] | * [[Tools:Linisher|Linishers (grinder and belt sander)]] | ||
- | Overseen by the [[woodworking|Woodworking Cause]]. | + | Overseen by the [[causes/woodworking|Woodworking Cause]]. |
*[[Tools:dropsaw|Drop Saw]] | *[[Tools:dropsaw|Drop Saw]] | ||
*[[Tools:tablesaws|Table Saws]] | *[[Tools:tablesaws|Table Saws]] | ||
Line 53: | Line 53: | ||
*[[Tools:WoodLathe|Wood Lathe]] | *[[Tools:WoodLathe|Wood Lathe]] | ||
*[[Tools:ThicknesserPlaner|Thicknesser and Planer]] | *[[Tools:ThicknesserPlaner|Thicknesser and Planer]] | ||
+ | *[[Tools:HandPowerTools|Hand Power Tools]] | ||
*[[Tools:Projectors|Projectors]] | *[[Tools:Projectors|Projectors]] |
