tools [2018/07/19 21:57] |
tools [2019/07/17 15:07] |
Line 13: | Line 13: | ||
Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | ||
* [[Tools:3dprinters|3D Printers]] | * [[Tools:3dprinters|3D Printers]] | ||
- | * [[Tools:LaserCutter|Laser Cutter]] | + | * [[Tools:3dresinprinters|Resin 3D Printer(s)]] |
+ | * [[Tools:LaserCutter|Red Laser Cutter]] | ||
* [[Tools:3Dscanner|3D Scanner Turntable]] | * [[Tools:3Dscanner|3D Scanner Turntable]] | ||
- | * Filastruder 3D printer filament extruder & recycler | + | |
- | * CR-10 Right | + | |
- | * CR-10 Left | + | |
* [[Tools:GreenRoomTV|Green Room TV]] | * [[Tools:GreenRoomTV|Green Room TV]] | ||
Line 54: | Line 53: | ||
*[[Tools:WoodLathe|Wood Lathe]] | *[[Tools:WoodLathe|Wood Lathe]] | ||
*[[Tools:ThicknesserPlaner|Thicknesser and Planer]] | *[[Tools:ThicknesserPlaner|Thicknesser and Planer]] | ||
+ | *[[Tools:HandPowerTools|Hand Power Tools]] | ||
*[[Tools:Projectors|Projectors]] | *[[Tools:Projectors|Projectors]] | ||
Line 60: | Line 60: | ||
Stations are tools that have a work flow and process around them that is documented. You can read more about them on the [[http://hsbne.org/admin/policy.html#stations|HSBNE Policy Page]]. | Stations are tools that have a work flow and process around them that is documented. You can read more about them on the [[http://hsbne.org/admin/policy.html#stations|HSBNE Policy Page]]. | ||
* [[Tools:PCBTank|PCB Etcher]] | * [[Tools:PCBTank|PCB Etcher]] | ||
+ | <nspages tools:> | ||
