tools [2019/01/07 11:18] |
tools [2019/10/08 12:16] |
Line 6: | Line 6: | ||
Overseen by the [[causes/craftpunk|Craft Punk Cause]]. | Overseen by the [[causes/craftpunk|Craft Punk Cause]]. | ||
- | * [[Tools:HeatPress|Heat Presses]] | + | <nspages tools:craftpunk -subns -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs> |
- | * [[Tools:SewingMachines|Sewing Machines]] | + | |
- | * [[Tools:Vacuformer|Vacuformer]] | + | |
- | * [[Tools:DesktopCNC|Desktop CNC]] | + | |
Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | ||
- | * [[Tools:3dprinters|3D Printers]] | + | <nspages tools:digitalfabrication -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs> |
- | * [[Tools:LaserCutter|Laser Cutter]] | + | |
- | * [[Tools:3Dscanner|3D Scanner Turntable]] | + | |
- | * Filastruder 3D printer filament extruder & recycler | + | |
- | * [[Tools:GreenRoomTV|Green Room TV]] | + | <nspages tools:greenroom -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs> |
- | * [[Tools:GreenRoomHandTools|Green Room Hand Tools]] | + | |
Overseen by the [[causes/electronics|Electronics Cause]]. | Overseen by the [[causes/electronics|Electronics Cause]]. | ||
- | * [[Tools:Desoldering|Desoldering Tools]] | + | <nspages tools:electronics -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs> |
- | * [[Tools:FunctionGenerators|Function Generators]] | + | |
- | * [[Tools:HotAir|Hot Air Tools]] | + | |
- | * [[Tools:Miscellaneous|Miscellaneous Electronics]] | + | |
- | * [[Tools:Multimeters|Multimeters]] | + | |
- | * [[Tools:Oscilloscope|Oscilloscope]] | + | |
- | * [[Tools:PowerSupplies|Power Supplies]] | + | |
- | * [[Tools:Soldering|Soldering Tools]] | + | |
- | * [[Tools:LabelMakers|Label Makers]] | + | |
Overseen by the [[causes/metalworking|Machine Shop Cause]]. | Overseen by the [[causes/metalworking|Machine Shop Cause]]. | ||
- | * [[Tools:superstack|Superstack Speaker]] | + | <nspages tools:metalshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs> |
- | * [[Tools:okadavm500cncmill|Okada VM500 CNC Mill]] | + | |
- | * [[Tools:3axismill.html|Pacific FTV-2S Turret Mill]] | + | |
- | * Lathes: | + | |
- | * [[Tools:Grey Lathe|Grey Lathe]] | + | |
- | * [[Tools:Mamalathe|Green Lathe]] | + | |
- | * [[tools:lathe_guide|How To: Turn a part]] | + | |
- | * [[Tools:BandSaw|Hafco BS-7DS Horizontal Band Saw]] | + | |
- | * [[Tools:SheetCNC|Sheet CNC Machine]] | + | |
- | * [[Tools:Linisher|Linishers (grinder and belt sander)]] | + | |
Overseen by the [[causes/woodworking|Woodworking Cause]]. | Overseen by the [[causes/woodworking|Woodworking Cause]]. | ||
- | *[[Tools:dropsaw|Drop Saw]] | + | <nspages tools:woodshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs> |
- | *[[Tools:tablesaws|Table Saws]] | + | |
- | *[[Tools:discsander|Disc Sander]] | + | |
- | *[[Tools:scrollsaw|Scroll Saw]] | + | |
- | *[[Tools:router|Router]] | + | |
- | *[[Tools:WoodLathe|Wood Lathe]] | + | |
- | *[[Tools:ThicknesserPlaner|Thicknesser and Planer]] | + | |
- | *[[Tools:HandPowerTools|Hand Power Tools]] | + | |
- | *[[Tools:Projectors|Projectors]] | + | <nspages tools:classroom -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs> |
- | *[[Tools:LaserPrinter|Laser Printer]] | + | |
- | ==== Stations ==== | + | |
- | Stations are tools that have a work flow and process around them that is documented. You can read more about them on the [[http://hsbne.org/admin/policy.html#stations|HSBNE Policy Page]]. | + | |
- | * [[Tools:PCBTank|PCB Etcher]] | + |
