tools [2019/06/08 00:41] |
— (current) | ||
- | ===== Summary ===== | ||
- | Tools documents the various things HSBNE operates, small to big. Laser Cutters, 3d Printers, PCB Etchers, Mills, Lathes, Saws, it all goes here. It is grouped by the area it is located in. | ||
- | ===== Areas ===== | ||
- | ==== Craft Punk ==== | ||
- | Overseen by the [[causes/craftpunk|Craft Punk Cause]]. | ||
- | * [[Tools:HeatPress|Heat Presses]] | ||
- | * [[Tools:SewingMachines|Sewing Machines]] | ||
- | * [[Tools:Vacuformer|Vacuformer]] | ||
- | * [[Tools:DesktopCNC|Desktop CNC]] | ||
- | ==== Digital Fabrication ==== | ||
- | Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | ||
- | * [[Tools:3dprinters|3D Printers]] | ||
- | * [[Tools:3dresinprinters|Resin 3D Printer(s)]] | ||
- | * [[Tools:LaserCutter|Red Laser Cutter]] | ||
- | * [[Tools:3Dscanner|3D Scanner Turntable]] | ||
- | ==== Green Room ==== | ||
- | * [[Tools:GreenRoomTV|Green Room TV]] | ||
- | * [[Tools:GreenRoomHandTools|Green Room Hand Tools]] | ||
- | ==== Electronics Bench ==== | ||
- | Overseen by the [[causes/electronics|Electronics Cause]]. | ||
- | * [[Tools:Desoldering|Desoldering Tools]] | ||
- | * [[Tools:FunctionGenerators|Function Generators]] | ||
- | * [[Tools:HotAir|Hot Air Tools]] | ||
- | * [[Tools:Miscellaneous|Miscellaneous Electronics]] | ||
- | * [[Tools:Multimeters|Multimeters]] | ||
- | * [[Tools:Oscilloscope|Oscilloscope]] | ||
- | * [[Tools:PowerSupplies|Power Supplies]] | ||
- | * [[Tools:Soldering|Soldering Tools]] | ||
- | * [[Tools:LabelMakers|Label Makers]] | ||
- | ==== Metal Shop ==== | ||
- | Overseen by the [[causes/metalworking|Machine Shop Cause]]. | ||
- | * [[Tools:superstack|Superstack Speaker]] | ||
- | * [[Tools:okadavm500cncmill|Okada VM500 CNC Mill]] | ||
- | * [[Tools:3axismill.html|Pacific FTV-2S Turret Mill]] | ||
- | * Lathes: | ||
- | * [[Tools:Grey Lathe|Grey Lathe]] | ||
- | * [[Tools:Mamalathe|Green Lathe]] | ||
- | * [[tools:lathe_guide|How To: Turn a part]] | ||
- | * [[Tools:BandSaw|Hafco BS-7DS Horizontal Band Saw]] | ||
- | * [[Tools:SheetCNC|Sheet CNC Machine]] | ||
- | * [[Tools:Linisher|Linishers (grinder and belt sander)]] | ||
- | ==== Wood Shop ==== | ||
- | Overseen by the [[causes/woodworking|Woodworking Cause]]. | ||
- | *[[Tools:dropsaw|Drop Saw]] | ||
- | *[[Tools:tablesaws|Table Saws]] | ||
- | *[[Tools:discsander|Disc Sander]] | ||
- | *[[Tools:scrollsaw|Scroll Saw]] | ||
- | *[[Tools:router|Router]] | ||
- | *[[Tools:WoodLathe|Wood Lathe]] | ||
- | *[[Tools:ThicknesserPlaner|Thicknesser and Planer]] | ||
- | *[[Tools:HandPowerTools|Hand Power Tools]] | ||
- | ==== Classroom ==== | ||
- | *[[Tools:Projectors|Projectors]] | ||
- | *[[Tools:LaserPrinter|Laser Printer]] | ||
- | ==== Stations ==== | ||
- | Stations are tools that have a work flow and process around them that is documented. You can read more about them on the [[http://hsbne.org/admin/policy.html#stations|HSBNE Policy Page]]. | ||
- | * [[Tools:PCBTank|PCB Etcher]] | ||
- tools.1559918468
