Next revision Both sides next revision
causes:blacksmithing [2019/08/28 14:35]
causes:blacksmithing [2020/04/14 13:59]
nogthree
Line 1: Line 1:
-====== Blacksmithing Cause ====== +====== Blacksmithing ​and Casting ​Cause ======
-Leader: ​Alan Webb +{{ :​causes:​forge.jpeg?​nolink|}}
-----+<​panel>​
 + ​**Location:​** The Forge is in the Hardstand, immediately to your right after the first container..\\
 + ​**Cause ​Leader:** \\
 + **Objective:​** The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing,​ metal forging and sand casting.\\
 + ​**Members:​** See [[https://​portal.hsbne.org/​cause/​list/​|Current List]]\\
 + ​**Communications:​** [[https://​forum.hsbne.org/​c/​cause-effect/​blacksmithing|Forums]] and #forge in [[https://​discord.gg/​avtkH5t|Discord Chat]].\\
 +</​panel>​
 +===== Cause Area Expectations =====
 +  * Please leave the area as clean or cleaner than you found it.
 +  * Please make sure to put money in the donation tin for consumables.
 +  * Please return tools to their homes.
-The main purpose of the blacksmithing ​area is to provide a self maintained and intuitive area to practise the art of blacksmithing,​ metal forging and sand casting.+===== Cause Owned Equipment =====
 +<nspages tools:blacksmithing ​-exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
-To reach this goal we have to complete the following items:+===== Member Owned Equipment on Loan =====
-To maintain ​clean, safe and organised smithy, there will be some small tasks that members will have to complete:+===== Ongoing Budgets =====
 +Monthly Consumables Discretionary - $100. This is discretionary budget for the Cause Leader
-After each use, the user much:+===== Current Goals =====
-  ​- Ensure that all tools are put away in their designated areas after use.+
 +===== Proposed Classes =====
 +===== Cleaning plan =====
 +When finished using the cause area, members must:
 +  ​- Ensure that all tools/equipment is put away in their designated areas after use.
   - The casting furnace is covered to protect it from rain.   - The casting furnace is covered to protect it from rain.
-  - Embers are either put out, or scuttled
   - Clean up any mess caused by work   - Clean up any mess caused by work
   - Gas cylinders are removed and locked in cage   - Gas cylinders are removed and locked in cage
 +  - donations for fuel/​consumables use left in donations tin/ through spacebucks
 Weekly tasks will include: Weekly tasks will include:
-  - Tool stock take +  - Sweeping the floor
-  - Extensive clean +  - emptying bins (steel recycling/​aluminium recycling/​rubbish)
-Monthly takes: +
-  - Space maintenance. +
-As for requests for the space the forum will be checked on a daily basis and all purchases with an overall price of $50 will be decided in a vote.+
-Meetings will have to be announced and will happen on Tuesdays when announced.+Monthly tasks:
 +  - stocktake of fuel
 +  - stocktake of tools
 +  - identification of improvement areas
-Appointment classes: Inductions on the blacksmithing and forging equipment.
-Monthly classes: How to draw and round a steel rod How to make a rail-road spike into a fire stokeHow to cast sand moulds+Meetings will  be announced with 7 days notice, ​and will happen on Tuesdays.
-Inductions can be held by any inducted ​member ​of the smithyForge welding+Inductions can be held by any member ​who has been inducted on the relevant equipment, in line with the cause operating policy.
-Future prospects: ​ Casting: Casting box + trays Ramming tools Cutters and Risers High temperature forges such as: Induction furnace Oil forge Smithing Power hammer Horizontal gas forge Misc Increase tooling (tongs for smelting)
-Ideally we would also like to move into building an oil forge or induction furnace. This would allow us to melt/​recycle higher temperature metals such as bronze and steel.
  • causes/blacksmithing
  • Last modified: 22 months ago
  • by zacmarcus
