causes:blacksmithing [2019/09/04 21:15] |
causes:blacksmithing [2020/04/14 13:59] nogthree |
- | Cause Leader: Alan Webb | + | {{ :causes:forge.jpeg?nolink|}} |
- | ---- | + | <panel> |
+ | **Location:** The Forge is in the Hardstand, immediately to your right after the first container..\\ | ||
+ | **Cause Leader:** \\ | ||
+ | </panel> | ||
- | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing, metal forging and sand casting. | + | ===== Cause Owned Equipment ===== |
+ | ===== Member Owned Equipment on Loan ===== | ||
+ | ===== Ongoing Budgets ===== | ||
When finished using the cause area, members must: | When finished using the cause area, members must: | ||
- causes/blacksmithing
- Last modified: 22 months ago
