causes:digitalfabrication [2019/06/08 17:08] |
causes:digitalfabrication [2020/04/14 14:44] nogthree |
- | <WRAP center round box 60%> | ||
====== Digital Fabrication Cause ====== | ====== Digital Fabrication Cause ====== | ||
+ | {{ :causes:digifab.jpg?nolink|}} | ||
+ | <panel type="default" title=""> | ||
**Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | **Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | ||
Line 8: | Line 9: | ||
**Members:** See [[https://portal.hsbne.org/cause/list/|Current List]] | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]] | ||
+ | **Recommended Suppliers**: [[https://wiki.hsbne.org/causes/digitalfabrication/suppliers|See here]]. | ||
**Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | **Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | ||
- | </WRAP> | + | **Operating Policy:** [[causes:digitalfabrication:operatingpolicy|Policy]] |
- | ===== Cause Area Expectations ===== | + | </panel> |
- | * Please leave the area as clean or cleaner than you found it. | + | |
- | * Please make sure to put money in the donation tin for consumables & tool use. | + | |
- | * Please return tools to their homes. | + | |
- | ===== Notable Equipment ===== | + | ===== Cause Area Rules ===== |
- | * Red [[tools:lasercutter|Laser Cutter]] | + | Please: |
- | * [[tools:3dprinters|FDM 3D Printers]]: Left CR-10, Right CR-10, Taz 5, Up Mini | + | * leave the area cleaner than you found it. |
- | * Resin 3D printer: [[tools:3dprinters:photon|Anycubic Photon]] | + | * don’t create mess in the Digifab room, our tools are sensitive to dust etc. |
- | * [[https://www.filastruder.com|Filastruder]], a 3D printer filament extruder & recycler | + | * return tools to their homes and don’t remove them from the Digifab room. |
- | * CAD modelling computer | + | * read the wiki before attempting to use a tool in Digital Fabrication. |
- | * Acrylic sheet bender | + | * don’t leave machines running unattended. |
+ | * don’t use tools that are marked as out of order. | ||
+ | * pay for all consumables you use unless they are for improving digifab or HSBNE infrastructure. | ||
+ | * don’t use your own consumables in a machine unless you have received permission from a maintainer of that machine. | ||
+ | <nspages tools:digitalfabrication -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | ||
- | [[tools:lasercutter|Red Laser cutter]] | + | **3D Printers:** |
+ | * Induction process is to demonstrate safe use of the machine while setting up a print. | ||
+ | * Maintainers are listed on the wiki for each machine. | ||
- | [[tools:lasercutter|Red Laser cutter]] | + | - Laser cutters: The machines themselves require supervision, so a supervisor must be around for the machines to be operated by anyone. |
- | ===== Process for becoming a Maintainer ===== | + | ===== Process for becoming a Supervisor ===== |
- | Tools are generally maintained by the maintainers listed on the relevant tool Wiki page, so check in with them before embarking on fixing a tool. | + | Becoming a Supervisor is not to be considered a shortcut to having unsupervised full access to a machine; it’s a role requiring a greater & more regular contribution of your time than a Maintainer. It means you know a machine well enough the you’re the person the Maintainers go to when they’re not sure of something. If you’re not already a Maintainer, start with that role first. |
- | ===== Ongoing Budgets ===== | + | Supervisors should have spent a reasonable amount of time as a Maintainer and can point to some recent tasks they have performed to maintain or improve the machine. If you’re stuck for tasks, ask the Cause Leader, other Maintainers or Supervisors, or check Trello for our current To-Do list. We try to keep some simple tasks aside just for newcomers, but if you feel they’re all too difficult, you’re welcome to have a go with finishing a task on one of our similar machines. Helping to bring an offline machine into operation is big brownie points. |
- | Monthly Consumables Discretionary - $100. This is for reimbursing purchases of cause consumables. | + | ===== . Ongoing Budgets ===== |
Line 50: | Line 83: | ||
- causes/digitalfabrication
