Both sides previous revision
causes:digitalfabrication [2019/08/17 17:23] |
causes:digitalfabrication [2020/01/22 20:56] |
**Members:** See [[https://portal.hsbne.org/cause/list/|Current List]] | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]] |
| **Recommended Suppliers**: [[https://wiki.hsbne.org/causes/digitalfabrication/suppliers|See here]]. |
**Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | **Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. |
</WRAP> | </WRAP> |
===== Cause Area Expectations ===== | ===== Cause Area Rules ===== |
* Please leave the area as clean or cleaner than you found it. | Please: |
* Please make sure to put money in the donation tin for consumables. | * leave the area cleaner than you found it. |
* Please don’t leave machines running unattended. | * don’t create mess in the Digifab room, our tools are sensitive to dust etc. |
* Please don’t create mess in the Digifab room, our tools are sensitive to dust etc. | * return tools to their homes and don’t remove them from the Digifab room. |
* Please return tools to their homes and don’t remove them from the Digifab room. | * read the wiki before attempting to use a tool in Digital Fabrication. |
* If a tool has dedicated consumables, please do not use your own in it. | * don’t leave machines running unattended. |
* If a tool has a dedicated workflow, please do not deviate from it. | * don’t use tools that are marked as out of order. |
* If a tool is broken or misbehaving, report it either on the Forums or Trello. | * pay for all consumables you use unless they are for improving digifab or HSBNE infrastructure. |
* Don’t use tools that are marked as out of order. | * don’t use your own consumables in a machine unless you have received permission from a maintainer of that machine. |
* Please read the wiki before attempting to use a tool in Digital Fabrication. | * precisely follow a tool’s workflow unless you have received permission from a maintainer of that tool to adjust it. |
| * report all broken or misbehaving tools using the “Report Issue” link in the portal or by sending an email to [[mailto:issues@hsbne.org|issues@hsbne.org]]. |
===== Notable Equipment ===== | ===== Cause Owned Equipment ===== |
<nspages tools:digitalfabrication -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | <nspages tools:digitalfabrication -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> |
To become a maintainer for any of the Digifab machines you must demonstrate competency to at least one of the existing Maintainers and the Cause Leader. The easiest way to do this is by doing some of the tasks on our Trello To-Do list, or by asking one of the Supervisors, other Maintainers or the Cause Leader for suitable tasks. | To become a maintainer for any of the Digifab machines you must demonstrate competency to at least one of the existing Maintainers and the Cause Leader. The easiest way to do this is by doing some of the tasks on our Trello To-Do list, or by asking one of the Supervisors, other Maintainers or the Cause Leader for suitable tasks. |
===== Ongoing Budgets ===== | ===== . Ongoing Budgets ===== |
| * Monthly consumables discretionary - $100. This is for purchases of cause consumables not included in any of the budgets below. |
Monthly Consumables Discretionary - $100. This is for reimbursing purchases of cause consumables. | * Quaterly filament discretionary - $300. This budget can be used every 3 months to buy new filament. |
| * Monthly repair discretionary - $150. This budget can be used to purchase new parts and cover any expenses related to repairs or upgrades of digifab tools as determined necessary by the cause leader. |
===== Current Goals ===== | ===== Current Goals ===== |
* How to Filastrude | * How to Filastrude |
===== Cleaning plan ===== | ===== Cleaning Policy ===== |
Digital Fabrication contains equipment that is sensitive to dust, and mess. The room must be vacuumed by users of the tools at least once a fortnight. | Digital Fabrication contains equipment that is sensitive to dust and mess. The room must be cleaned by users of the tools according to the signage in the room and this policy. There is a whiteboard in the room that indicates the last time cleaning happened. If it has been longer than the requirement for the tool you’re using, you must vacuum the room and wipe down all horizontal surfaces. You will be dinged and referred to the executive for a potential ban (depending on the case) if you ignore this rule. |
