causes:digitalfabrication [2019/08/17 17:23] |
causes:digitalfabrication [2020/01/22 20:59] |
Line 8: | Line 8: | ||
**Members:** See [[https://portal.hsbne.org/cause/list/|Current List]] | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]] | ||
+ | **Recommended Suppliers**: [[https://wiki.hsbne.org/causes/digitalfabrication/suppliers|See here]]. | ||
**Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | **Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | ||
- | ===== Cause Area Expectations ===== | + | ===== Cause Area Rules ===== |
- | * Please leave the area as clean or cleaner than you found it. | + | Please: |
- | * Please make sure to put money in the donation tin for consumables. | + | * leave the area cleaner than you found it. |
- | * Please don’t leave machines running unattended. | + | * don’t create mess in the Digifab room, our tools are sensitive to dust etc. |
- | * Please don’t create mess in the Digifab room, our tools are sensitive to dust etc. | + | * return tools to their homes and don’t remove them from the Digifab room. |
- | * Please return tools to their homes and don’t remove them from the Digifab room. | + | * read the wiki before attempting to use a tool in Digital Fabrication. |
- | * If a tool has dedicated consumables, please do not use your own in it. | + | * don’t leave machines running unattended. |
- | * If a tool has a dedicated workflow, please do not deviate from it. | + | * don’t use tools that are marked as out of order. |
- | * If a tool is broken or misbehaving, report it either on the Forums or Trello. | + | * pay for all consumables you use unless they are for improving digifab or HSBNE infrastructure. |
- | * Don’t use tools that are marked as out of order. | + | * don’t use your own consumables in a machine unless you have received permission from a maintainer of that machine. |
- | * Please read the wiki before attempting to use a tool in Digital Fabrication. | + | * precisely follow a tool’s workflow unless you have received permission from a maintainer of that tool to adjust it. |
Line 60: | Line 63: | ||
To become a maintainer for any of the Digifab machines you must demonstrate competency to at least one of the existing Maintainers and the Cause Leader. The easiest way to do this is by doing some of the tasks on our Trello To-Do list, or by asking one of the Supervisors, other Maintainers or the Cause Leader for suitable tasks. | To become a maintainer for any of the Digifab machines you must demonstrate competency to at least one of the existing Maintainers and the Cause Leader. The easiest way to do this is by doing some of the tasks on our Trello To-Do list, or by asking one of the Supervisors, other Maintainers or the Cause Leader for suitable tasks. | ||
- | ===== Ongoing Budgets ===== | + | ===== . Ongoing Budgets ===== |
- | + | * Monthly consumables discretionary - $100. This is for purchases of cause consumables not included in any of the budgets below. Purchases that form part of this budget must be approved by the cause leader. | |
- | Monthly Consumables Discretionary - $100. This is for reimbursing purchases of cause consumables. | + | * Quarterly filament discretionary - $300. This budget can be used every 3 months to buy new filament. Purchases that form part of this budget must be approved by the cause leader. |
Line 76: | Line 80: | ||
- causes/digitalfabrication
