causes:digitalfabrication [2020/01/22 20:56] |
- | <WRAP center round box 60%> | + | ====== Digifab Cause ====== |
- | ====== Digital Fabrication Cause ====== | + | {{ : causes:digifab.jpg?direct&600|The digifab room}} |
- | **Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | + | <WRAP> |
- | **Recommended Suppliers**: [[https://wiki.hsbne.org/causes/digitalfabrication/suppliers|See here]]. | ||
Line 32: | Line 31: | ||
- Laser cutters: The machines themselves require supervision, so a supervisor must be around for the machines to be operated by anyone. | - Laser cutters: The machines themselves require supervision, so a supervisor must be around for the machines to be operated by anyone. | ||
Line 64: | Line 63: | ||
===== . Ongoing Budgets ===== | ===== . Ongoing Budgets ===== | ||
- | * Monthly consumables discretionary - $100. This is for purchases of cause consumables not included in any of the budgets below. | + | * Monthly consumables discretionary - $100. This is for purchases of cause consumables not included in any of the budgets below. Purchases that form part of this budget must be approved by the cause leader. |
- | * Quaterly filament discretionary - $300. This budget can be used every 3 months to buy new filament. | + | * Quarterly filament discretionary - $300. This budget can be used every 3 months to buy new filament. Purchases that form part of this budget must be approved by the cause leader. |
* Monthly repair discretionary - $150. This budget can be used to purchase new parts and cover any expenses related to repairs or upgrades of digifab tools as determined necessary by the cause leader. | * Monthly repair discretionary - $150. This budget can be used to purchase new parts and cover any expenses related to repairs or upgrades of digifab tools as determined necessary by the cause leader. | ||
- causes/digitalfabrication.1579690619
