causes:electronics [2019/06/08 17:05] |
causes:electronics [2020/04/14 14:45] nogthree |
+ | <panel> | ||
**Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | **Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | ||
**Cause Leader:** Brendan (nog3) Halliday\\ | **Cause Leader:** Brendan (nog3) Halliday\\ | ||
Line 5: | Line 6: | ||
**Members:** See [[https://portal.hsbne.org/cause/list/|Current List]]\\ | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]]\\ | ||
**Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | ||
+ | **Operating Policy:** [[causes:electronics:operatingpolicy|Policy]] | ||
+ | </panel> | ||
Line 12: | Line 16: | ||
* Please don’t leave irons or other tools on when you’re not immediately using them. | * Please don’t leave irons or other tools on when you’re not immediately using them. | ||
* Please return tools to their homes. | * Please return tools to their homes. | ||
Currently none of our tools require supervision. | Currently none of our tools require supervision. | ||
Line 27: | Line 35: | ||
Line 48: | Line 55: | ||
* To be held every (or every second) Saturday from midday till 1:30pm\\ | * To be held every (or every second) Saturday from midday till 1:30pm\\ | ||
* How to read schematics and construct circuits\\ | * How to read schematics and construct circuits\\ | ||
* Making a radio\\ | * Making a radio\\ | ||
* Basic electronic measurement and component characteristics\\ | * Basic electronic measurement and component characteristics\\ | ||
* Soldering class\\ | * Soldering class\\ | ||
* Oscilloscope measurement and basic AC circuits\\ | * Oscilloscope measurement and basic AC circuits\\ | ||
* Basic circuit analysis and component calculation\\ | * Basic circuit analysis and component calculation\\ | ||
* The transistor and you\\ | * The transistor and you\\ | ||
* Introduction to opamps\\ | * Introduction to opamps\\ | ||
* Introduction to 555 timer\\ | * Introduction to 555 timer\\ | ||
* Introduction to logic gates\\ | * Introduction to logic gates\\ | ||
* Introduction to microcontrollers\\ | * Introduction to microcontrollers\\ | ||
* The arduino, reading sensors\\ | * The arduino, reading sensors\\ | ||
* Remote reading and switching\\ | * Remote reading and switching\\ | ||
* Basic circuit troubleshooting\\ | * Basic circuit troubleshooting\\ | ||
* Electronic circuit strategy (building blocks of circuit design)\\ | * Electronic circuit strategy (building blocks of circuit design)\\ | ||
* Making a PCB\\ | * Making a PCB\\ | ||
* Designing a PCB\\ | * Designing a PCB\\ | ||
Line 86: | Line 76: | ||
There are pictures of the bench in a clean state, please return them to it. Label where stuff should go and put it there if it isn't. Ensure that members who use the electronics workbench do the same. | There are pictures of the bench in a clean state, please return them to it. Label where stuff should go and put it there if it isn't. Ensure that members who use the electronics workbench do the same. | ||
+ | {{tag>electronics}} | ||
- causes/electronics
