Both sides previous revision
causes:woodworking [2016/03/15 12:20] |
causes:woodworking [2018/12/01 14:01] |
====== Woodworking Cause ====== | ====== Woodworking Cause ====== |
==== Goals ==== | The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Craig Hudson-Taylor. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. |
Safety First. Make some great things for the space and create some awesome projects all while learning some new skills. | We currently hang out every **Thursday from 6pm onwards**, come by and have a chat, build some things! |
==== Champion ==== | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]] |
* Adam Blake ## Members | ==== Guidelines ==== |
* Needs updating | |
==== Development Plan ==== | * All machinery requires induction. |
| * All machine or tool damage requires immediate reporting to contact@hsbne.org . |
| * Appropriate PPE usage is clearly signed and expected. |
| * You are expected to clean up after you use the shop, do not leave projects on work surfaces, or dust/shavings/glue about the shop. |
| * Return all tools to their home in the shop when done. |
| * Woodshop tools do not leave the woodshop. |
| * Use the marked sacrificial surfaces for most work, ie do not saw, hammer etc on the mitre station or machine surfaces. |
| * Some tools have removable parts, when done with the tool all those parts should be reattached or placed back where you found them. |
| * Machine maintenance is to be performed by named maintainers only, please do not attempt to modify any woodshop machines. |
* Add tools and consumables. | ==== Inductions ==== |
* Machine interlocks - (pending electronics hardware) | |
* Consumables and Project storage | |
* Room arrangement | |
* Add computer to room | |
* Dust Extraction for major tools | |
==== Cleaning plan ==== | Inductions are currently run as required, please check the HSBNE Facebook page to see any upcoming inductions, or ask in our Discord channel if there doesn't seem to be anything. |
Each member will clean up after themselves. Clean-up during/after weekly meetings and classes. | ==== Consumables ==== |
==== Maintenance Plan ==== | The Woodshop provides: |
Broken or tools needing maintenance to be marked with appropriate ticket. | * PVA Glue |
| * Some assorted screws/nails |
| * Machinery blades (scrollsaw, bandsaw, table saws etc) |
| * Some sanding materials |
==== Consumables: ==== | An assortment of relevant project parts, such as castors, drawer slides etc may be found in the boneyard. |
Each member is expected to supply their own consumables for projects. We will help out where we can with tools and material. | The boneyard also has an assortment of free-to-members wood that has been donated. |
==== Classes ==== | ==== Standard Materials & Suppliers ==== |
*TBA | * 90x45 MGP10 Framing Pine (Bunnings) |
| * 16mm MDF (Bunnings) |
| * 12mm AA Marine Ply (https://www.marineplywoodqld.com.au/) |
Starts the 9th February 2015. | ==== Shop Contents ==== |
==== Part of every class ==== | === Machines === |
* Safety and PPE | |
* Tool induction - Safety, Use, Maintenance | |
* Clean-up | |
==== Upcoming Classes ==== | |
* Powertools 101 //sharp and noisy// | |
* Handtools 101 //Hammertime// | |
* Equipment maintenance cleaning and sharpening 101 //sharpest tool in the shed// | |
* Small CNC 101 //fancy whirly gig// | |
* Materials 101 //to wood or not to wood// | |
* Make a jewellery or tool box | |
* Shelving for the space //so things can rest easy// | |
==== Future Classes ==== | |
* Chainsaw 101 point away from face | |
* Bush furniture | |
* Planter box / Garden stuff | |
* Build the space a couch (collaboration with creatorium) | |
* Doors, hinges, locks, windows, sliders everything that opens and shuts | |
* Frames building faster than termites can eat | |
==== Induction ==== | |
*TBA | |
==== Weekly Meetings ==== | |
*TBA | |
| * PS-12 Sliding Table Saw |
| * N4400 Bandsaw |
| * H&F Mini Bandsaw |
| * A3-31 Jointer/Planer Thicknesser |
| * Hitachi Drop/Mitre Saw |
| * Radial Arm Saw |
| * Disc Sander |
| * Scrollsaw |
| * Lathe |
| === Power Tools === |
| TBA |
| === Hand Tools === |
| TBA |
