Both sides previous revision
causes:woodworking [2018/03/05 14:42] |
causes:woodworking [2020/04/05 10:30] |
====== Woodworking Cause ====== | ====== Woodworking Cause ====== |
The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Craig Hudson-Taylor. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Ian Roving. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. |
We currently hang out every **Thursday from 6pm onwards**, come by and have a chat, build some things! | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]]. |
| {{:causes:woodshop-room.jpg?direct&600|The woodshop room as of 02/02/2019}} |
| //(The woodshop room as of 02/02/2019)// |
==== Guidelines ==== | ==== Guidelines ==== |
* All machinery requires induction. | * All machinery requires induction. |
* All machine or tool damage requires immediate reporting to contact@hsbne.org . | * All machine or tool damage requires immediate reporting to contact@hsbne.org . |
* Appropriate PPE usage is clearly signed and expected. | * Appropriate PPE usage is clearly signed and expected. |
* You are expected to clean up after you use the shop, do not leave projects on work surfaces, or dust/shavings/glue about the shop. | * You are expected to clean up after you use the shop, do not leave projects on work surfaces, or dust/shavings/glue about the shop. |
* Return all tools to their home in the shop when done. | * Return all tools to their home in the shop when done. |
* Woodshop tools do not leave the woodshop. | * Woodshop tools do not leave the woodshop. |
* Use the marked sacrificial surfaces for most work, ie do not saw, hammer etc on the mitre station or machine surfaces. | * Use the marked sacrificial surfaces for most work, ie do not saw, hammer etc on the mitre station or machine surfaces. |
* Some tools have removable parts, when done with the tool all those parts should be reattached or placed back where you found them. | * Some tools have removable parts, when done with the tool all those parts should be reattached or placed back where you found them. |
* Machine maintenance is to be performed by named maintainers only, please do not attempt to modify any woodshop machines. | * Machine maintenance is to be performed by named maintainers only, please do not attempt to modify any woodshop machines. |
==== Inductions ==== | ==== Inductions ==== |
The boneyard also has an assortment of free-to-members wood that has been donated. | The boneyard also has an assortment of free-to-members wood that has been donated. |
| ==== Standard Materials & Suppliers ==== |
| * 90x45 MGP10 Framing Pine (Bunnings) |
| * 16mm MDF (Bunnings) |
| * 12mm AA Marine Ply (https://www.marineplywoodqld.com.au/) |
| You can [[causes:woodworking:suppliers|See a list of companies to buy supplies at here]]. |
=== Machines === | === Machines === |
| <nspages tools:woodshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> |
* PS-12 Sliding Table Saw | |
* N4400 Bandsaw | |
* H&F Mini Bandsaw | |
* A3-31 Jointer/Planer Thicknesser | |
* Hitachi Drop/Mitre Saw | |
* Radial Arm Saw | |
* Disc Sander | |
* Scrollsaw | |
* Lathe | |
=== Power Tools === | === Power Tools === |
TBA | * [[tools:woodshop:handpowertools|Power handtools]] |
=== Hand Tools === | === Hand Tools === |
TBA | TBA |
