causes:woodworking [2018/03/05 14:43] |
causes:woodworking [2020/04/14 14:41] nogthree Adding top section. |
- | + | {{:causes:woodshop-room.jpg?direct|The woodshop room as of 02/02/2019}} | |
- | The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Craig Hudson-Taylor. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | + | <panel> |
- | + | **Location:** The woodworking cause os located in the big shed, in the large room on the eastern side of the building.\\ | |
- | We currently hang out every **Thursday from 6pm onwards**, come by and have a chat, build some things! | + | **Cause Leader:**Joshua (devians) Hogendoorn \\ |
+ | **Objective:** The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Ian Roving. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving.\\ | ||
+ | **Communications:** [[https://forum.hsbne.org/c/cause-effect/woodworking|Forums]] and #woodchop in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | ||
+ | **Operating Policy:** [[causes:woodworking:operatingpolicy| Operating Policy]]\\ | ||
+ | </panel> | ||
- | * All machinery requires induction. | + | * All machinery requires induction. |
- | * All machine or tool damage requires immediate reporting to contact@hsbne.org . | + | * All machine or tool damage requires immediate reporting to contact@hsbne.org . |
- | * Appropriate PPE usage is clearly signed and expected. | + | * Appropriate PPE usage is clearly signed and expected. |
- | * You are expected to clean up after you use the shop, do not leave projects on work surfaces, or dust/shavings/glue about the shop. | + | * You are expected to clean up after you use the shop, do not leave projects on work surfaces, or dust/shavings/glue about the shop. |
- | * Return all tools to their home in the shop when done. | + | * Return all tools to their home in the shop when done. |
- | * Woodshop tools do not leave the woodshop. | + | * Woodshop tools do not leave the woodshop. |
- | * Use the marked sacrificial surfaces for most work, ie do not saw, hammer etc on the mitre station or machine surfaces. | + | * Use the marked sacrificial surfaces for most work, ie do not saw, hammer etc on the mitre station or machine surfaces. |
- | * Some tools have removable parts, when done with the tool all those parts should be reattached or placed back where you found them. | + | * Some tools have removable parts, when done with the tool all those parts should be reattached or placed back where you found them. |
- | * Machine maintenance is to be performed by named maintainers only, please do not attempt to modify any woodshop machines. | + | * Machine maintenance is to be performed by named maintainers only, please do not attempt to modify any woodshop machines. |
Line 33: | Line 37: | ||
The boneyard also has an assortment of free-to-members wood that has been donated. | The boneyard also has an assortment of free-to-members wood that has been donated. | ||
+ | ==== Standard Materials & Suppliers ==== | ||
+ | * 90x45 MGP10 Framing Pine (Bunnings) | ||
+ | * 16mm MDF (Bunnings) | ||
+ | * 12mm AA Marine Ply (https://www.marineplywoodqld.com.au/) | ||
==== Shop Contents ==== | ==== Shop Contents ==== | ||
- | + | <nspages tools:woodshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | |
- | * PS-12 Sliding Table Saw | + | |
- | * N4400 Bandsaw | + | |
- | * H&F Mini Bandsaw | + | |
- | * A3-31 Jointer/Planer Thicknesser | + | |
- | * Hitachi Drop/Mitre Saw | + | |
- | * Radial Arm Saw | + | |
- | * Disc Sander | + | |
- | * Scrollsaw | + | |
- | * Lathe | + | |
=== Power Tools === | === Power Tools === | ||
- | TBA | + | * [[tools:woodshop:handpowertools|Power handtools]] |
=== Hand Tools === | === Hand Tools === | ||
TBA | TBA |
- causes/woodworking
