Both sides previous revision
causes:woodworking [2018/12/01 14:01] |
causes:woodworking [2020/01/31 23:31] |
====== Woodworking Cause ====== | ====== Woodworking Cause ====== |
The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Craig Hudson-Taylor. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Ian Roving. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. |
We currently hang out every **Thursday from 6pm onwards**, come by and have a chat, build some things! | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]]. |
You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]] | {{:causes:woodshop-room.jpg?direct&600|The woodshop room as of 02/02/2019}} |
| //(The woodshop room as of 02/02/2019)// |
==== Guidelines ==== | ==== Guidelines ==== |
* 16mm MDF (Bunnings) | * 16mm MDF (Bunnings) |
* 12mm AA Marine Ply (https://www.marineplywoodqld.com.au/) | * 12mm AA Marine Ply (https://www.marineplywoodqld.com.au/) |
| You can [[causes:woodworking:suppliers|See a list of companies to buy supplies at here]]. |
=== Machines === | === Machines === |
* PS-12 Sliding Table Saw | * [[/tools/woodshop/tablesaws|PS-12 Sliding Table Saw]] |
* N4400 Bandsaw | * [[tools:woodshop:bandsaw|N4400 Bandsaw]] |
* H&F Mini Bandsaw | * [[tools:woodshop:smallbandsaw|H&F Mini Bandsaw]] |
* A3-31 Jointer/Planer Thicknesser | * [[tools:woodshop:thicknesserplaner|A3-31 Jointer/Planer Thicknesser]] |
* Hitachi Drop/Mitre Saw | * [[tools:woodshop:dropsaw|Hitachi Drop/Mitre Saw]] |
* Radial Arm Saw | * [[tools:woodshop:drillpress|Drill Press]] |
* Disc Sander | * [[tools:woodshop:beltanddisksander|Belt and Disk Sander]] |
* Scrollsaw | * [[tools:woodshop:spindlesander|Spindle Sander]] |
* Lathe | * [[tools:woodshop:drumsander|Drum Sander]] |
| * [[tools:woodshop:discsander|Disc Sander]] |
| * [[tools:woodshop:scrollsaw|Scrollsaw]] |
| * [[tools:woodshop:lathe|Lathe]] |
| * [[tools:woodshop:dustextraction|Dust Extraction]] |
| * [[tools:woodshop:handtools|Hand Tools]] |
=== Power Tools === | === Power Tools === |
TBA | * [[tools:woodshop:handpowertools|Power handtools]] |
=== Hand Tools === | === Hand Tools === |
TBA | TBA |
